SR-3230 sponge rollers
  • ABS tect
    • Sep 2013
    • 511
    Lazy question...
    Anyone got an easier way to replace the sponge gathering rollers for the output shift tray? I always damage the foam on these and didn't know if y'all had any tricks.
  • ridgemill
    • Sep 2017
    • 192
    Re: SR-3230 sponge rollers
    I use SP6-160-004 to drop the output tray and a spring hook / small screwdriver to remove the clip.
    Or, you can remove the output tray and the metal plate it sits on; to give you easier access.
    • luca72
      • Oct 2017
      • 1792
      Originally posted by ABS tect
      Lazy question...
      I would advise you to put a sheet of paper in the slot, so as not to drop clips, screws, or various parts inside, this will save you wasting time.
      make a sachet in your tool bag with a suite of all clip sizes inside, salvaged from scrapped machines, wouldn't you want to block the job for a stupid clip or special screw rolled under some furniture? ... LOL
      "I'll be back"
