Hard Drives on Ricoh Models
  • monstercopier
    • Jun 2019
    • 60
    Hi Techs...has anyone attempted to use SSD drives to replace 320gb standard hard drive.
    if so what size Hard drive did you install?
    250GB or 500GB?
    Ricoh Models 3504/4504/6004
    Ricoh Models 4054/5054/4055/5055
    K
  • tonerhead
    • Sep 2009
    • 582
    Re: Hard Drives on Ricoh Models
    250GB or 500GB?
    K
    We have, works fine so far. Been using 500gb. We have one tech that thinks he has figured out why the hdd's fail so often. He said he has set the hdd erase on the copier from dod three pass to random number single pass. Lot less wear on hdd.
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
    • KeviM
      • Oct 2019
      • 324
      This is an interesting question.
      I've tried a 160GB SSD on a Ricoh MP2550 and it didn't work.
      Anybody got any additional information on this?
        • 37532
        The original HDD size for the 2550 was 80GB. I have had problems in the past with Ricohs not liking drives that were 50% larger.
        • KeviM
          • Oct 2019
          • 324
          I put in a 1TB hard drive when I couldn't get an 80GB or 160GB and it's worked fine.
          • tonerhead
            • Sep 2009
            • 582
            Was it new? Was it formatted prior to the copier?
            • rthonpm
              • Aug 2007
              • 2859
              Generally any unformatted hard drive with the right connector will work. Just remember that the system will format the drive to the size of the factory installed one. So a larger drive just ends up with a lot of unused space. With smaller drive sizes becoming harder to find, there's not much choice but to use drives much larger than the device would have originally used.
              • KeviM
                • Oct 2019
                • 324
                It was brand new.
                • KeviM
                  • Oct 2019
                  • 324
                  Absolutely correct. I've experienced this as well
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    Yep...we use Toshiba 320gb IDE drives on ALL Ricohs....have to try an SSD
                    • copier tech
                      • 8174
                      The HDD erase is off by default so do you guys enable this option on every device ?
                      • Gift
                        • Mar 2011
                        • 2459
                        Since HDD aren't excluded in service contracts we don't always turn it on and you definetly shouldn't do this after replacing a HDD with SSD. KM removed this feature with the i-series/after moving to solid stage discs.
                        • rthonpm
                          • Aug 2007
                          • 2859
                          Hopefully you mean SATA and still don't have any machines that need IDE drives out in the field. If you do, you're not going to find 3.5 inch IDE SSD drives.
                          Sent from my BlackBerry using Tapatalk
                          • KeviM
                            • Oct 2019
                            • 324
                            IDE?...
                            IDE is really old technology. Thought all ricoh machine hard drives from about 12 years ago till present is SATA?
                            • Gift
                              • Mar 2011
                              • 2459
                              good luck finding a 2.5" 320gb drive with IDE connector, I'm pretty shure he got that confused
