Imc 3000-controler-nvram zero counter
  • Johnysg11988
    • Feb 2019
    • 14
    [Misc] Imc 3000-controler-nvram zero counter
    Hello
    I' ve imc3000.I had proplem with controler board and nvram zero counter due electricity issue.I replaced the parts but the copier shutdown after one minute when start up
    Ant suggestions..
    • 37533
    Re: Imc 3000-controler-nvram zero counter
    You may have additional issues.
    • Johnysg11988
      • Feb 2019
      • 14
      Nop..because replaced the parts on onother new machine and the problem to be tha same
      • copier tech
        • 8174
        If you have another machine to 'borrow' boards from try the the BICU and power supply.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          Any codes displayed at all?
          • Johnysg11988
            • Feb 2019
            • 14
            No nothing..copier shutdown after "please wait"
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              I KNOW this sounds like a stoopid question but check that the nvram is facing the right way.
              Make sure that the "D" impression in the eprom matches the impression on the board...it fits BOTH ways but only works ONE way.
              • Gift
                • Mar 2011
                • 2459
                I think he wrote that the parts don't work on another, new IMC with the same symptome.
                What happens with the original NV Ram? Same problem?
                Did you order the corrent part number? Ricoh Manuals can be a bit confusing sometimes - in the past you got a SC though, I managed that myself thanks to using an outdated parts manual LOL
                And yes, the NV Ram fits in both ways but you should look for the markings to choose the proper way - guess we all learned that at some point, too
                Not shure if that's valid anymore but did you compare/adjust the Dip SW?
                Does this board use onboard RAM or a module? In case there's a module you should cross-check that, too.
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  That sounds like the ops panel main board.
                  Hit it.
                  • Johnysg11988
                    • Feb 2019
                    • 14
                    Thanks a lot...finaly ram was the problem
