MP4055 Cant Rotate Sort
  • laser801
    • May 2014
    • 151
    Hey Folks, I have a weird issue on this MP4055 where the Rotate Sort is not working. As soon as I send 2 sheets through the ADF it stops and says "Load 8 1/2 paper in another tray"... I have loaded 8 1/2 paper in all four trays in both orientations different ways in each tray and still same thing...The Display reads all the correct sizes and orientations, When I change the trays up as well. Also set the specific sizes in paper tray settings. The Machine works fine otherwise picking specific sizes as needed either way without using Rotate sort. Did a Firmware upgrade too. Anything would be appreciated. Thanks in Advance, Laser801
  • Gift
    • Mar 2011
    • 2459
    Re: MP4055 Cant Rotate Sort
    That's funny - did you make any fancy paper type settings or specific tray exclusions from auto paper select? I think in classic copy mode you'd see some hints in the paper tray buttons (like a key or medium/thick paper..)
    • laser801
      • May 2014
      • 151
      Thanks for your Reply...I thought the same, but no, All trays are set up normal... I even tried changing all 4 trays around many times, Auto Select and then specifically setting them to 8 1/2 x 11... Its just the Rotate Sort that wont work, Everything else is fine. Crazy!
      • Gift
        • Mar 2011
        • 2459
        OK..pretty odd... are all trays really set to "auto size detection" or are there manual entered settings present? I had a case with a detection problem hardware-wise and entered the size manually to bypass the problem. I think I ended up that it seemed to be a valid solution but the customer called me again because certain features didn't worked anymore. This was really long time ago so I can't recall any specifics. I also would check if there's paper behind the cassete confusing the detection mechanism/sensors.
        Out of interest: Is the problem reproduceable if you use EU A4 format (perhaps you can improvise yourself some sample sheets with 210 mm x 297 mm.
          • 37476
          8 1/2 by what? What have you selected as the starting tray? Be aware, the bypass tray cannot be used for rotate sort. Are you also trying to do one-sided to two-sided with only 2 originals?
          • KeviM
            • Oct 2019
            • 324
            Can the machine sort? I'm not asking about rotate sort here, just standard sorting without a sorter
            • laser801
              • May 2014
              • 151
              Thanks, I can try that. I did try Auto detect as well as manual setup...
              • laser801
                • May 2014
                • 151
                No, it cannot sort.
                • laser801
                  • May 2014
                  • 151
                  8 1/2 x 11, Tray 1 is the starting tray, and not using Bypass, and just single sided...I have tried every Tray 1-4, with both orientations in each. Tried Auto Detect and Manual setup for size...New Firmware...Thinking of just swapping out the ADF Unit...All I got left. Who's with Me !!??? Thanks
                  • KeviM
                    • Oct 2019
                    • 324
                    No, it cannot sort.
                    I believe in order for sort to work you need additional memory or a hard drive installed. Maybe that's the reason why it's not working.
                    Just check if the additional memory or hard drive is installed and functioning properly. I have had similar problems with other models because of the memory or hard drive not working properly.
                    All the best friend
                      • 37476
                      Not having a machine in front of me to check but there might some setting in either user tools or SP mode that is blocking rotate sort such as a tray being restricted for use with only one function like fax or printing. Try loading tray 1 Letter LEF, Long Edge Feed, and all the others with SEF. If it works, see which tray it feeds from.
                        • 23006
                        I don't know this particular Ricoh ... but on Kyoceras if you install any finisher it disables the Auto-Rotate Sort function. It only works if there is no finisher AND if you have paper of both orientations. =^..^=
                        • anothertech
                          • 1768
                          Yes I think you're right, there should be a setting in user tools to turn on/off rotate sort.
                          Had it recently on an IMC 4500, probably the same setting.
                          • tsbservice
                            Field tech
                            • 8007
                            Criss-cross sorting. Basic setting of most if any A3 machine. You can turn it off but of course on purpose.
                            • KeviM
                              • Oct 2019
                              • 324
                              Excellent suggestion. I forgot about that. Nice 1
