MP C2003 fuser
  • deputydogg
    • Nov 2015
    • 172
    MP C2003 fuser
    Machine is displaying replace fuser unit. Does it have a hard stop at some point or will it continue to run ? I see the fixing film assembly is available, does it typically come with the reset fuse ?
    Thanks,
    Dave
  • Gift
    • Mar 2011
    • 2444
    Re: MP C2003 fuser
    Thanks,
    Dave
    There's a hard stop some thousand pages after the message. You can clear the PM counter and maybe squeeze out more pages - you need that fuse to clear certain fuser SC codes but not for regular pm reset.
    • luca72
      • Oct 2017
      • 1677
      Re: MP C2003 fuser
      Thanks,
      Dave
      yes, as Gift says, it quietly resets the SP of the PM, I always do it too, the unit lasts much longer than stated, as regards the prints ... the message is displayed at 415k, and at 430k the machine stops, so the customer has an autonomy of 15k prints, after the replacement warning message.
      "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
      • emiliorsg
        • Jul 2018
        • 141
        Re: MP C2003 fuser
        I seem to remember that at 240K it gives the pm warning and at 400K it gives an sc code that must be reset with a pico fuse.
        • sandmanmac
          • 3963
          Re: MP C2003 fuser
          For the C2003/ 2503 the PM warning is 240K. Hard stop at 248K (unless the Counters are reset obviously) is the way I understand it.
          I can't speak to how much beyond the PM cycle they may work reliably. I only sell and work on the C3003 and up in that line, which have much higher PM's which I think is the info that Luca has provided, although my Italian is a little rusty
            • 36766
            Re: MP C2003 fuser
            240K is the recommended yield for the C2003. 400K is the yield for the faster models.
