MPC 5503 SC204 only when print color
+ More Options
Posts
  • alopz89
    • Nov 2020
    • 2
    I have replace laser unit (LD unit) and bicu pcb..still come up sc204 but only when color print and copy
  • copier tech
    • 8196
    Re: MPC 5503 SC204 only when print color
    Did you fit a new or used LSU & follow the procedure in the service manual ?
    Try updating the firmware.
    • Code: SC204-00
    • Description:Polygon Motor: XSCRDY Signal Error During polygon motor rotation, the XSCRDY signal was inactive (H) for longer than one rotation of the polygon.
    • Causes:Remedy:
    โ€‹
    • alopz89
      • Nov 2020
      • 2
      • Code: SC204-00
      • Causes:Remedy:
      I replaced used one,the procedure u mean the c and a adjustment?
      • emiliorsg
        • Jul 2018
        • 141
        Have you changed the whole laser unit? Have you performed SP2-111-004: Forced Line Position Adj. Mode d? If it's still the same, try changing the IPU PCB.
        • luca72
          • Oct 2017
          • 1791
          check the ground plate of the ITB cleaning unit, and the spring contact of transfer roller, can create electric noise, look the bullettin that i attached.
          "I'll be back"
          • Gift
            • Mar 2011
            • 2459
            Sweet - that bulletin reminded me of older MPC generations (I think MPC4000/5000) and occasional ground issues with the right door/transfer roller holder assembly - they also triggered LD/polygon motor SC codes.
