ProC5100 Fiery E-22B - "No Boot Device" after System Software reinstallation
  • mrwho
    Major Asshole!
    • 4299
    [Misc] ProC5100 Fiery E-22B - "No Boot Device" after System Software reinstallation
    Good morning, people.
    I've been fighting this one for some days now, and I'm running out of ideas.
    This Fiery had problems that required me to do a software reinstallation on it.
    Problem is, no matter how hard I try, I can't get it to boot.
    Things I've tried:
    - Installing from USB (following the Service Manual's guide)
    - Installing via crossover cable (same)
    - A different PSU
    - A different HDD
    - Installing from USB using a different pendrive
    - Tried to change BIOS settings, from UEFI boot to Legacy, to resetting to defaults.
    I even tried to boot from a lightweight linux to see if the files are on the HDD, and it appears to me that they are (there are several partitions also).
    I've installed the System Software several times on several Fierys both from Konica Minolta and Ricoh, and this is the first time I'm hitting this wall.
    Anyone has any idea of what this could be?
    Thanks in advance!
    Mascan42
    Ibid
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: ProC5100 Fiery E-22B - "No Boot Device" after System Software reinstallation
    Was the HDD you fitted a proper Fiery one or just a normal off the shelf one?
    Hit it.
    • mrwho
      Major Asshole!
      • 4299
      The second HDD I tried was off-the-shelf, but the original HDD is the one that came fitted with it and has been working so far...
      Mascan42
      Ibid
      • TonerMunkeh
        Professional Moron
        • 3865
        It may still have a problem. Fiery HDD's have proprietary partitions on them and they don't like off the shelf HDD's. Order the one out of the parts catalog.
        Hit it.
        • luca72
          • Oct 2017
          • 1724
          [ATTACH=CONFIG]52923[/ATTACH]
          Things I've tried:
          - A different PSU
          - A different HDD
          Thanks in advance!
          it seems an error more from a pc than from a machine / printer.
          try disabling "boot from network board" from the bios and check
          setting the boot sequence of disks / media
          ex. 1-hdd 2-cdrom 3-usb...etc..etc
          It also checks the battery backup of the motherboard
          it could be a motherboard failure.
          • mrwho
            Major Asshole!
            • 4299
            Finally managed to make it boot.
            After several trials and tribulations, what managed to solve the booting problem was replacing the SATA cable and connecting it to a different motherboard connector (along with the HDD replacement earlier, as the original had died - I tried it with a SATA-USB adaptor and it was indeed dead).
            I still need to go to the customer and connect it to the 5100 and finish the configuration, but at least the booting problem is solved.
            Will keep you posted. Thanks for all of your input.
            Mascan42
            Ibid
            • satins
              • Feb 2021
              • 89
              I can only relate with it as this is the last thing you suspect.
              It never happened with IDE connectors.
              I guess sometimes you have let the past go and figure out the new problem as it keeps the world running,
              I hope you have upgraded it with the new one with locks on it.
              • mrwho
                Major Asshole!
                • 4299
                I got the cables from another (dead) computer - and it's working, and if it works I won't mess with it again. But next time it dies, first thing I'll try is to change the SATA cable before anything else.
                The Fiery is at the customer's machine and working nicely.
                Two things I learned from this:
                - Is still perfectly acceptable to replace the HDD with a off-the-shelf one;
                - If you mess with the BIOS settings, a BIOS reset will put everything back as it should be (it's mentioned in the service manual).
                Thanks and cheers!
                Mascan42
                Ibid
                • trandinhvu1425
                  • Aug 2022
                  • 2
                  Thanks and cheers!
                  can you give me the e22b system software file, i would be very grateful
                  • mrwho
                    Major Asshole!
                    • 4299
                    Hello.
                    Sorry, no - left the business, deleted everything related to it. Just like a bad marriage.
                    Mascan42
                    Ibid
