SC400 - RICOH MP C2051
  • Nauman
    • 28
    [Error Code] SC400 - RICOH MP C2051
    My Ricoh C20512 keeps giving me this code SC 400, in the begining i was able to turn off the power and back on and it use to work fine. Later i also tried clearing up the code going into System SP , with executing Fusing Reset and turning the Machine On/Off . Now all of a sudden none of the methods working and cant use the machine any more due the code SC 400.
    Any advise ?
  • mrwho
    Major Asshole!
    • 4299
    Re: SC400 - RICOH MP C2051
    Clean the ID sensors. As a stopgap measure, change SP3324-06 to 1. Change it back to default after cleaning the sensors.
    Mascan42
    Ibid
    • Nauman
      • 28
      Thank You very much .. I have change the code and it worked.. i haven't changed back to default 3.50 .. have changed it to 1 as you said. and it copied/printed and scanning.
      • luca72
        • Oct 2017
        • 1780
        Originally posted by Nauman
        Any advise ?
        as suggested above, clean id sensors, also check that the ITB belt is not cut, by sliding it with two thumbs of the hand along its entire length
        "I'll be back"
        • Nauman
          • 28
          Thank You luca72 i will check on it as well
          • mrwho
            Major Asshole!
            • 4299
            If you don't clean the sensors, when the problem comes back changing the SP might not solve your problem.
            As I said, changing the SP is just a temporary solution.
            And yes - check the belt for any damages.
            Mascan42
            Ibid
            • Nauman
              • 28
              Once again appreciate your concern and feedback, am definitely going to clean the Sensors and checking on the ITB aswell.
              Much appreciate your and Luca72 feedback.
              Thank You
              • Gift
                • Mar 2011
                • 2459
                + check the density, this series likes shifting to faint solids. In this state the ID sensors (should be clean of course) have a rough time reading the MUSIC markings.
                • Nauman
                  • 28
                  Got It ..
                  • Oze
                    Ricoh Fanboy
                    • 1663
                    Also ...just a reminder that "cleaning the density sensors" involves removing the ITB anyways....itb...waste toner bottle #2 and black pcdu out.
                    Wipe over the sensor windows with a DAMP cloth.
                    I just thought I'd tell you how to do it seeing as you tried to use a fuser sc clear to clear a density error
                      • 37491
                      Not necessary. Just follow the instructions for replacing the ID sensor board only leave the cable connected. You can swing the board our far enough to clean it. After cleaning there is an SP that need to be ran. The following is from the bulletin on it:
                      • GIUBOSS
                        • 1435
                        Also in my opinion it could be time to replace the black pcdu group, it could dust more than usual if beyond the scheduled maintenance cycle.
