ricoh mpc 2050 - color scan problem -
  • tullio
    • Feb 2012
    • 268
    printer color , ok
    problems with color, ardf and glass top scans -printing and photocopy in color and black and white ok. color scanning only - black and white scanning ok.
  • Gift
    • Mar 2011
    • 2459
    Re: ricoh mpc 2050 - color scan problem -
    I can't recognize any problem on this 5dpi sample image - can't you just upluad the original file somewhere?
    WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free is easy to use imho
    • tullio
      • Feb 2012
      • 268
      colorful background.
      WhatsApp Image 2022-04-14 at 13.01.10.jpgWhatsApp Image 2022-04-14 at 13.01.10.jpg
      • Gift
        • Mar 2011
        • 2459
        Still I can't really see how "even" the background is over the entire image - a bent scanner frame can cause problems like this or the CCD values have been resettet for some reason (you can compare with the data from birth sheet). Besides this the MPC2050 is pretty old so the scanner lamp might have lost too much of it's initial peak brightness.
        • rthonpm
          • Aug 2007
          • 2854
          Have you tried cleaning the optics? There's likely enough of a film on them that the colour scan feature sees it as part of the image. Hold a flashlight up to the optics at an angle and you'll likely see a haze or film to clean off the mirrors.
          • GIUBOSS
            • 1436
            Printer and copy do not have the same calibration, did you do the calibration in the machine menu? , User tools, maintenance. Did you clean the laser?
            • sandmanmac
              • 3981
              100 % that there has been a memory clear performed or something like that and the settings are out of whack.
              Without the non-default sheet it may be tricky to get that back.
              And Mr. Tullio.......why not use that C2050 to scan a document and upload a PROPER PDF SAMPLE? I mean.... Seriously
