Ricoh MP7500, 8000, 8001, 7502, 7001, 6001, light copies after change transfer belt
  • chinyee
    • Apr 2022
    • 5
    HI these riocoh Martini modal , i have 2 uni MP 8000 & MP7502 , both i have same problem which is after i change NEW original Ricoh Transfer belt, then the printout become light BUT when i revert back to the ols transfer belt the printour is fine
    anyone have same issue ??
    P/s : i have try wil 3 ricoh new transfer belt none are working.
    thnak you
  • rthonpm
    • Aug 2007
    • 2854
    Re: Ricoh MP7500, 8000, 8001, 7502, 7001, 6001, light copies after change transfer be
    Have you also changed the rest of the PM parts?
    Sent from my BlackBerry using Tapatalk
    • chinyee
      • Apr 2022
      • 5
      yes new drum, dev and magnetic roller >>
      the problem is when i use the old belt its fine, then change to new belt become blur ..., i though is there any setting for transfer belt ??
        • 37489
        All Genuine Ricoh or are you wasting money on cheap Chinese knock offs?
        • satins
          • Feb 2021
          • 89
          thnak you
          I have faced this issue.
          I figured out that the problem is primarily with storage of the transfer belt but that was a while back.
          I believe it had lost some of its default charge characteristics with the long storage.
          However, it may come back to life if you hook it in the machine for another 4-5 days (if you can) and wait...
          • chinyee
            • Apr 2022
            • 5
            Thank for the suggestion, i will give a try, indeed the storage for this belt is quite long. Hopefully can solve. Tq
            • GIUBOSS
              • 1435
              thnak you
              I would have stopped at the first new transfer belt, if original.
              • stani
                • Jan 2013
                • 49
                As satins sad, it can be in issue with long storage. If you have an old transfer unit, you can try installing your new transfer belt in it and leave for some days to let the tension release. Afterwards install the stretched transfer belt in your machine.
                • giovanio
                  • 28
                  Try changing the transfer values ​​from the service program
                  • chinyee
                    • Apr 2022
                    • 5
                    cause
                    what sp value you suggest, i like to try also ,
                    BUT anyway the density imporve day by day already , most due to long storage
                    • rapper
                      • 11
                      Is the contact on the transfer unit good?
                      I remember there was an old bulletin on the Aficio650, right on the copper contact.
                      • luca72
                        • Oct 2017
                        • 1778
                        thnak you
                        what code does the belt have? could it be that you have mounted that of the 6503? the manufacturer has recently been changed.
                        was there a sheet in the box with the values to be corrected? ... try these, at most you put them back as they were before....give a try
                        "I'll be back"
                          • 37489
                          thnak you
                          I am wondering why you replaced just the transfer belt? If it was because of light copies, the problem most likely was not the belt. The majority of the time when I have had light copies and prints with any martini it has been a dirty ID sensor caused by toner haze buildup. For the martini the value of SP 3001-001 should be in the range of 1 to 70 depending upon the specific model. Anything above that and you either have a dirty or bad sensor.
