Photoconductor unit not set correctly ricoh mpc3003
  • Pixtech Frameworks
    • May 2020
    • 238
    Hi All,
    I am currently battling a Ricoh mpc3003 whose welcome not is Photoconductor Unit not Set for Cyan, Black and Yellow. I tried putting another unit from 6003 same thing. What could be the cause. Your contributions are highly appreciated.
  • semi
    • Sep 2008
    • 195
    Re: Photoconductor unit not set correctly ricoh mpc3003
    Bent pin on one of the connectors-look very closely
    • GIUBOSS
      • 1436
      Originally posted by Pixtech Frameworks
      Hi All,
      I would like to know if the groups are original, the toners? Try to pull them, clean the chip contacts. Check that all doors are closed correctly
        • May 2020
        • 238
        I've found solution, I had to unplug the the developer unit cable of all the Units and remove them, open side paper transfer section and front cover for 3hrs. Inserted units back and power on machine and it was back to normal
        • GIUBOSS
          • 1436
          You've also solved in economics ... Ricoh also plays these fake contact jokes
            • May 2020
            • 238
            Exactly, could be contact malfunctions.
              • 37533
              More that likely the 3 hour wait was not needed.
                • May 2020
                • 238
                I decided to wait 3hrs cos I've tried different Photoconductor units, still the unit not set correctly.. So I unplugged all cables and all doors
                • Zaxxon
                  • 608
                  agree! 2.30 hours should be enough
                  unplugging all
                  Please start you post with brand, model, problem.
                    • May 2020
                    • 238
                    unplugging all
                    Really?? Then what was needed to do??? Does it mean a machine error was detected??.
                      • 37533
                      Try the following:
                      1. Use the control panel power to turn the C3003 off
                      2. Unplug the power cord
                      3. Press and hold the control panel power button until the power LED flashes, normally about 10 seconds.
