I have a customer who would like to use user codes but have them not apply for a range of IP addresses. Anything sent from that specified range should print regardless if it authenticates or not. According to Ricoh and the manuals this is possible by turning on User Authentication > User Codes > Printer Job Authentication > Simple Limitation > Set the IP range.
For the life of me I cannot get this to work and have spent hours on it. I even tried anable Admin Authentication first then enabling codes (Ricoh's suggestion) but it is still denying jobs from the IP range specified.
Has anyone else tried this? BTW, this is not the same as Access Control Range which is completely different.
Savin model C5050
Ricoh MPC5000
Savin model C5050
Ricoh MPC5000
