CA State Copier Machine(s) - Unable to load System SP
  • craigp
    • Jan 2018
    • 34
    Hey guys,
    Picked up about 6 machines from the CA State last week. I'm trying to reset the admin password but each time I press on it, it beeps and then stops.
    I am assuming the IT department forgot to unlock the machines. Is there a way around this so I can start using them by editing settings?
  • Reed
    • Feb 2011
    • 261
    Re: CA State Copier Machine(s) - Unable to load System SP
    try logging win with Supervisor, no password
    • sandmanmac
      • 3990
      If that doesn't work, it will have to be reset in Factory mode, and no one should be posting that procedure here in a public forum.
      You're not on to anything new here. There are dozens of threads related to resetting passwords.
      The procedure is the same for basically every model
        • 37641
        But if Service Mode is disabled by the Administrator,can you get into Factory mode or will it require replacing the NVram?
        • sandmanmac
          • 3990
          Fine question!
          I'm honestly not sure if Factory mode is available in that case, but my guess is that it is; However, there's no indication based on his initial post that that's the case here at all imo.
          • anothertech
            • 1771
            Yes factory mode should be available, if he can figure out the key sequence to get into factory mode.
              • 37641
              If there is, it is not the method that I have used access Factory reset to clear administrator and supervisor passwords or to change some of the settings that Ricoh has moved to Factory Mode. I wonder if there is a way to clear the supervisor password by TELNETTing in to the base OS?
              • craigp
                • Jan 2018
                • 34
                Unfortunately, logging in without a password in Supervisor account is not successful
                  • 37641
                  If you are with an authorized Ricoh dealer, submit a request for a support visit from the Regional service rep. There is a link for submitting a request on TSRC. Otherwise call the Product Support at 1-800-333-2679. Getting 6 machines saleable should be worth paying for a support visit.
                  • tonerhead
                    • Sep 2009
                    • 582
                    Here you go. This should reset passwords.
                    To reset supervisor/admin passwords
                    Reset, reset, 1,4,3,clear,clear(hold)
                    SP5846-46
                    At least it used to do it.
                    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
                    Especially when it comes to sex
                      • 37641
                      SP5846-46
                      But will it work if the machine is in Service Lockout.
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        Still no mention of model number(s) here.
                        • craigp
                          • Jan 2018
                          • 34
                          Even with the System SP Settings, when I click on System SP it does not want to click. So kinda stuck here.
                          • craigp
                            • Jan 2018
                            • 34
                            The model is Savin MP C5503
                              • 37641
                              Here are a couple YouTube videos that Ricoh knowledge published back in 2014. They might prove helpful.
                              You may also want to see if the SOP Designer is still available from rfgesource.
