Ricoh mpc3003 - problem of maegine.foto.
  • tullio
    • Feb 2012
    • 268
    In print the margins are not correct. Copy and other documents ok.
    [ATTACH=CONFIG]53340[/ATTACH] [ATTACH=CONFIG]53341[/ATTACH] thanks for your help.
  • Gift
    • Mar 2011
    • 2456
    Re: Ricoh mpc3003 - problem of maegine.foto.
    Back to the basics:
    1.
    Check if the paper has been placed properly and if the size matches what the MFP detects and display in the tray icons.
    2.
    Use the internal "trimming area" test pattern to both check and if needed adjust the print image properly for all trays and duplex.
    3.
    Once this is OK you can check and adjust the scanner and finally the DF.
    If the copy registration looks "okayish" it's still possible that some retard who serviced the machine before you fiddled around with the scanner adjustments first to compensate a bad printer alignment with test copies
    Edit: PS - afterwards you might check the egde erase margins, too. Unless "borderless print" isn't enabled there sshould be a white border ~5mm leading edge and 3mm all other edges..
    • luca72
      • Oct 2017
      • 1813
      the wrong margin, is it equal to the millimeter on all printed sheets, or is the measurement random? ....try to uninstall the printer driver, and reinstall, use pcl6
      "I'll be back"
      • UNICORNico
        • May 2018
        • 308
        Originally posted by Gift
        Back to the basics:
        1. Check if the paper has been placed properly and if the size matches what the MFP detects and display in the tray icons.
        2. Use the internal "trimming area" test pattern to both check and if needed adjust the print image properly for all trays and duplex.
        3. Once this is OK you can check and adjust the scanner and finally the DF.
        I agree with the partner.
        "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
