MP 5054 SC 995-01
  • normy945
    • Apr 2018
    • 10
    MP 5054 SC 995-01
    I am a retired Ricoh tech helping out a friend...
    After replacing board with network port damage (port was ripped off board) Before replacement Machine worked fine except for network connectivity.
    Installed replacement board and am getting
    RICOH MP5054 SC Code 995-01
    went to sp5-811 and check serial number it was right , so erased and reentered it, still get error
    Please Help
  • dalewb74
    • Feb 2018
    • 1162
    Re: MP 5054 SC 995-01
    from what i see in the service manual, you have done everything right.
    • sandmanmac
      • 3983
      I don't know how you've determined that?
      We actually have almost ZERO info about what he's actually done, other than pop in a controller. He has not indicated referring to a Service manual of any sort to do this.
      New or used Controller?
      New NVrams or original ones from old board?
      What if you reinstall the old board? Is the behavior the same as before?
      Any chance it had an SED drive installed? I've never dealt with this personally, but there's a very specific procedure for controller replacement if so.
      Respectfully, I'd expect a lot more detail about what you've actually done from a former Ricoh Tech
        • 37553
        Please Help
        Did the new(?) board come with NVram? If you installed the NVram from the old board, check that it is properly seated and that no leads are bent under or broken.
        Are you sure it was the correct CTRL PCB. There are more than one in the parts catalog. They are based on the region that the end product was manufactured for. Also the board for the 25/30/35 ppm model are different from the 40/50/60 ppm models.
        • luca72
          • Oct 2017
          • 1790
          Please Help
          summarizing:
          you transported the nvram = ok
          you did the sps for serial number transport, and it turns out ok, right?
          do so take out the birth certificate with all sp settings of the machine, or if there is no print one from an identical one mp5054
          try to reactivate printer / scanner with 5-985 set to 1 both
          turn off and turn on the machine, update firmware, turn off and turn on, run sp801 engine, turn off and turn on
          verify and adjust the sp parameter in according with certificate of birth, basicaly the sp 1001 family, and 4609-4610-4611 put to default.
          "I'll be back"
