ricoh mpc2003, jams
  • tullio
    • Feb 2012
    • 268
    ricoh mpc2003, jams
    Hello. i replaced the fuser, same problem. someone has this problem? thank you.
    WhatsApp Image 2022-05-25 at 20.08.24.jpgWhatsApp Image 2022-05-25 at 20.21.15.jpg
  • 8T2
    • Aug 2015
    • 257
    Re: ricoh mpc2003, jams
    Any condensation on the fuser exit guide when the paper gets stuck?
    Sent from my SM-A305F using Tapatalk
    • tullio
      • Feb 2012
      • 268
      the fuser is new. changed it.
      • GIUBOSS
        • 1435
        I think he was referring to damp paper, which in my opinion should jam after many pages and not the first sheet .... right?
        Is it the same machine as the thread: Ricoh, Savin, Gestetner, Lanier?
          • 37487
          When he didn't get an answer to this one within an hour, he posted the other one which is actually a violation of one of the General Rules. No wonder he has accumulated so many Red Cards.
          • Gift
            • Mar 2011
            • 2459
            If you zoom in you can see the paper is rolled/pressed together behind the fuser exit guide flap - so the fuser is pushing OK but there's no transport happening in the paper exit area. It's either a mechanical thing (sticky duplex gate, drive failure, obastacle) or a sensor problem. Shouldn't be hard to find out with some SP input/output check testings.
            • 8T2
              • Aug 2015
              • 257
              Correct. Have had paper damp enough to jam on first page coming out fuser/exit section or even sticking to transfer roller or drum in severe cases.
              • Gift
                • Mar 2011
                • 2459
                Yeah paper might be an option if this an occasional jam or a "monday morning" thing.
                • UNICORNico
                  • May 2018
                  • 308
                  If I may add a suggestion, I would try to try the orientation of the sheet horizontally (A4 -> A4-R) and perform a test to check if it gets stuck in the same area.
                  With the orientation changed, the device works at a slower speed, allowing the heat to be better distributed by the paper.
                  At least to me this has gotten me out of some trouble when the paper had some moisture and the client is annoyed that he blames the xD paper ha ha ha!!!!
                  "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
