Ricoh mpc3003 , printing problem.
  • tullio
    • Feb 2012
    • 268
    Ricph mpc3003 margin not centered in print. How can i center it? In a4 and a3 same problem . Jpeg, pdf, etc.
    THE PRINT IS NOT CENTERED ON THE SHEET. IN PRINT.WhatsApp Image 2022-06-03 at 08.30.26.jpgWhatsApp Image 2022-06-03 at 08.30.26.jpg
  • GIUBOSS
    • 1436
    Re: Ricoh mpc3003 , printing problem.
    Check the settings shown in the certificate (if you find it), check the spacers of the drawers, clean all the rubber rollers in all the sections where the paper flow, check the technical manual ...
    • Gift
      • Mar 2011
      • 2459
      ah dude.....
        • 37533
        If you don't even know how to adjust registration, it is ho wonder that you have collected so many red cards.
        • luca72
          • Oct 2017
          • 1784
          THE PRINT IS NOT CENTERED ON THE SHEET. IN PRINT.[ATTACH=CONFIG]53504[/ATTACH][ATTACH=CONFIG]53505[/ATTACH]
          if you print this files on another mf/printer, the result its ok?
          "I'll be back"
