Aficio MP4001
  • copyman
    Owner / Technician
    • Sep 2005
    • 4700
    Aficio MP4001
    Don't know Ricoh that well. Going to be replacing the web roller on this MP4001. Do I need to reset the counter to get rid of message on the display? If so what # is it in the SP mode?
    Thanks in advance
  • sandmanmac
    • 3981
    Re: Aficio MP4001
    Thanks in advance
    Yes.
    Reset with SP7804-005
    • luca72
      • Oct 2017
      • 1778
      Re: Aficio MP4001
      Thanks in advance
      sp 1-902 = % of web used, put to "0" and press "#" to clear web consumption status
      "I'll be back"
        • 37488
        Re: Aficio MP4001
        Originally posted by sandmanmac
        Yes.
        Depending on the firmware version it may requiring doing both at the same time as well as SP 7806-008. First time I did one I had to call tech support. He told me it was a problem that had just been brought to their attention. He said there was a new bulletin which we got that day after I left on calls and told me the corrected procedure.
        • KeviM
          • Oct 2019
          • 324
          Re: Aficio MP4001
          Slimslob is right. You may need to do both. Make a note of both the reset codes.
          I learnt this 1 the hard way.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4700
            Re: Aficio MP4001
            Thanks to everyone for the great advice!
            Best of luck you to all of you!
            • KeviM
              • Oct 2019
              • 324
              Re: Aficio MP4001
              You welcome. Don't stress friend. You got this
