Ricoh Firmware Update Tool - Processing Status: Error
  • lurker1652
    • Mar 2021
    • 58
    • 37556
    Re: Ricoh Firmware Update Tool - Processing Status: Error
    There have been a bunch of Update Tool failures lately on entry level models. Read some of the other threads in both Ricoh forums.
    • lurker1652
      • Mar 2021
      • 58
      After power cycling the printer, I'm stuck at 99% of a new attempt of upgrade (1 hour and counting)
        • 37556
        There are recovery procedures in other recent posts. If you have the time to wait an hour, you have the time to search the Ricoh forums.
        • copier tech
          • 8192
          • lurker1652
            • Mar 2021
            • 58
            You’ll find its easier & safer to update the old way via SD card.
            You can also update the apps too which you can’t with the tool.
            the tool uses rfu files, which have different extension of what romdata (fwu) uses. Are there interchangeable?
              • 37556
              the tool uses rwu files, which have different extension of what romdata (fwu) uses. Are there interchangeable?
              NO!!! But you can push them to the MFP from WIM, one file at a time. There is at least one other method that I have seen quoted recently but have never used it. See post #7 in this thread: https://www.copytechnet.com/forums/r...7=#post2151686
              • lurker1652
                • Mar 2021
                • 58
                Interestingly enough, I managed to reproduce the printer hung status pushing the first file through WIM using web upload.
                • mikadonovan
                  • May 2008
                  • 2931
                  If any type of custom firmware is currently loaded on the machine, the RFUT will not work right.
                  NEVER ASSUME ANYTHING
                  • anothertech
                    • 1771
                    Did you get the machine working, or is it down?
                    • lurker1652
                      • Mar 2021
                      • 58
                      Had to power cycle the printer, then it came back. Update did not succeed though. Same behaviuor trying to use the Ricoh Update Tool and just going through the Web Interfase, so probably is a printer or firmware thing, not a tool thing.
                      • lurker1652
                        • Mar 2021
                        • 58
                        How to I identify an "offending"/custom firmware?
                        • mikadonovan
                          • May 2008
                          • 2931
                          It's been my experience that custom modules begin with the letter "C". There may be more, I don't know for sure.
                          • anothertech
                            • 1771
                            Post a list of your current firmware, someone will spot the custom firmware.
                            Try using the SD card method, update one firmware at a time until it fails, then you'll know which one is giving you a problem.
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3944
                              That happens a lot with used machines; you have no idea what their pedigree is.
                              Rarely, if ever, does custom firmware ever get replaced with a production version at the end of a lease, or when the machine is sold outright.
