Good companions of Printing and Copying.
I am assailed by a doubt and I want to turn to the sages of the forum.
The Fusing Sleeve Unit systems, so that it has been possible to verify through the documentation, do not indicate anything that in the preventive ones they must be lubricated, and only indication is made to the replacement, in case of breakage. Has anyone been able to assess an estimate of use to lubricate them with silicone and extend the useful life? Or does the wear and tear occur in the same way, and is the waste of time in disassembling the Fusing Sleeve Unit irrelevant?
I comment because in some models and made this "re-lubrication", increasing the pressure a little (a few millimeters) the mulles that act with the Pressure Roller, thus gaining some more efficiency in the fusion.
