RICOH M C2000 SP MODE???
  • anothertech
    • 1762
    #16
    Re: RICOH M C2000 SP MODE???
    Originally posted by Tich
    Well with other Ricoh's I've tried, press() depending with the model then lastly pressing the C button. But with this one it doesn't have the button that's why I asked
    That service mode information is not to be posted on an open forum, would you take that post down please?
    If not, maybe we can get the moderator to remove it.
    • davel
      • Oct 2011
      • 1097
      #17
      Just out of curiosity, how do you log into the sp mode for the Ricoh M C2000
      Just to clarify, are you referring to MP C2000 or IM C2000?
      • anothertech
        • 1762
        #18
        Doesn't matter, does it?
          • 37394
          #19
          He said there was no yellow key. I believe that the MP has a yellow key as it only came with a normal operation panel. It was a slowed down version of the MP C2030 at only 20 ppm and was available as a basic copier with SPF as an option.
          • davel
            • Oct 2011
            • 1097
            #20
            True. SP mode access should not be posted.
            • DRichard
              • May 2008
              • 482
              #21
              Originally posted by sandmanmac
              You need to bring up the keypad on the screen -either by the process listed in the SERVICE MANUAL, or by using one of the "Classic Apps" (Copier / Scanner/Fax).
              Secondly, the second # sequence you listed to enter SP mode is close, but incorrect
              Document Server function will have the keypad on its screen no matter the old or new modes...
              "Enjoy every sandwich."
              -- Warren Zevon
              • Tich
                • Jun 2022
                • 5
                #22
                Also the IM C2000 most likely has the ability to change the normal SP access code. There is also the possibility that Service lockout is enabled in User Tools.
                I have tried bringing up the screen through those ways that is why i had to bring it here. According to the manual "This machine has a service menu. For how to enter the SP Menu mode, contact the supervisor in yourbranch office". Please note this is an M C2000 not an IM C2000.
                • Tich
                  • Jun 2022
                  • 5
                  #23
                  Yes the keypad is popping up but the Reset button is not available to complete the key combination.
                  • Tich
                    • Jun 2022
                    • 5
                    #24
                    All true, but my guess is straight up lack of knowledge - since he apparently can't even find the keypad
                    Well i think the point this forum was created is to share knowledge isn't it? At least have a look at the model & try log in then help me with the steps you used
                    • davel
                      • Oct 2011
                      • 1097
                      #25
                      M C2000 came out after I was made redundant so I can’t help you. I thought you might have had MP C2000 same as MP C4500 over 15 years old.
                        • 37394
                        #26
                        That procedure is Ricoh company confidential information. They have already changed the default because too many unauthorized people knew the old one.
                        Look on the serial number plate. There should be a Produce Code, probably a D followed by 3 or 4 additional numbers or letters. that product code will tell us exactly what model you have.
                        Have you tried using the Classic Copier like sandmanmac suggested?
                        • sandmanmac
                          • 3979
                          #27
                          I m must admit that I initially assumed he was referring to an IM C2000 in the original post, then later thought it might be an MP C2000.
                          I just googled a Ricoh M C2000 and it is apparently a model in India (?)
                          I didn't spend much time, but it's an oddball for sure.
                          The brochure didn't show the OP panel very well, but it definitely isn't an SOP, nor does it seem to resemble an MP C2000. It sort of looks like a larger version of the MP301 OP Panel from what I can tell .
                          I'd ask the poster to provide a picture of the OP panel if possible? I have ZERO documentation about this one.
                          RICOH M C2000 Brochure.pdf
                            • 37394
                            #28
                            [ATTACH]53843[/ATTACH]
                            The only thing I can find are drivers and the Operation Manual. Available on Ricoh, Ricoh-Europe and Ricoh-SA(South America). Driver download also reference the G3020c possibly a printer only version. There is no Clear modes key. Maybe if Debs logs in she might be able to pull up some information at the help desk.
                            • Debs1964
                              • Oct 2010
                              • 1690
                              #29
                              M C2000.jpgThis is the panel, but we don't appear to have that model in the UK, I can't find any information regarding SP mode
                              There are 10 types of people in this world, those who understand binary maths and those who don't
                              • UNICORNico
                                • May 2018
                                • 308
                                #30
                                I have just managed by Ricess a query about this, by coincidences of fate, we are in the process of making sales of this model. If you provide me with the instructions, then I send them to you privately, to whoever needs it.
                                "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
