RICOH M C2000 SP MODE???
  • wilbert.c
    • Apr 2014
    • 24
    [Error Code] RICOH M C2000 SP MODE???
    Hello team, i want to try and clear an error on a ricoh "M C2000". How do i enter the sp mode?
  • mikadonovan
    • May 2008
    • 2931
    Re: RICOH M C2000 SP MODE???
    What is the SC code?
    NEVER ASSUME ANYTHING
    • wilbert.c
      • Apr 2014
      • 24
      sc547
      • mikadonovan
        • May 2008
        • 2931
        That is a fuser error. The problem in the fuser will have to actually be fixed first.
        • wilbert.c
          • Apr 2014
          • 24
          Yes I agree it's fusing error I'm suspecting cold weather could be cause so I wanted to clear the code
            • 37475
            SC547 is a Zero Cross error. Could be really crappy power at the wall or the main power supply in bad. It is a type D so once the cause is corrected you only need to turn the power off and back on, no reset code needed.
            • Defective fusing lamp relay
            • Defective fusing lamp relay circuit
            • Unstable power supply
            1. Check the power supply source.
            2. Replace the PSU
            • Zaxxon
              • 608
              We have machines that are in cold rooms where the temperature is below 5 degrees Celsius, so I do not think cold weather can give the error, unless the printer is located outside.
              Please start you post with brand, model, problem.
                • 37475
                I had a martini series in a portable building at a prison. During cold weather it would throw SC 542 if the overnight dropped below 60 F overnight in the building. Told them not to turn the copier on until the heat had been on 30 minutes. End of problem.
                • Tich
                  • Jun 2022
                  • 5
                  Just out of curiosity, how do you log into the sp mode for the Ricoh M C2000
                  • davel
                    • Oct 2011
                    • 1103
                    • Tich
                      • Jun 2022
                      • 5
                      Well with other Ricoh's I've tried the reset button, pressing 107 or 826182 depending with the model then lastly pressing the C button. But with this one it doesn't have the reset/yellow button that's why I asked
                      • luca72
                        • Oct 2017
                        • 1774
                        try to clean with cotton-fioc and alcool, or fine sand paper, the conctact of big connector that connect the fuser unit to machine, in both side, keep carefull do not fold the pin.....i dont remember if must do so reset(?) could be also the switch of the front panel
                        "I'll be back"
                        • sandmanmac
                          • 3981
                          You need to bring up the keypad on the screen -either by the process listed in the SERVICE MANUAL, or by using one of the "Classic Apps" (Copier / Scanner/Fax).
                          Secondly, the second # sequence you listed to enter SP mode is close, but incorrect
                            • 37475
                            Also the IM C2000 most likely has the ability to change the normal SP access code. There is also the possibility that Service lockout is enabled in User Tools.
                            • sandmanmac
                              • 3981
                              All true, but my guess is straight up lack of knowledge - since he apparently can't even find the keypad
