Ricoh Mp 9000
  • antoney suresh das
    • May 2011
    • 103
    Ricoh Mp 9000
    Hi Every one on the Forum,
    I need help from you guys .From one of my customers i got a call that the machine was not booting just a please wait
    screen. On inspecting the machine I found that one of the HDD was making some humming noise i disconnected
    that particular HDD the machine booted but the duplex option is not available. I then replaced 2 HDD of same capacity
    and make but the duplex option is still not available .The HDD cannot be detected by the machine .
    Can some one please suggest how do i go about from here.
    Regards
  • UNICORNico
    • May 2018
    • 308
    Re: Ricoh Mp 9000
    Regards
    Have you performed the previous change/replace steps so that the machine can operate with the new HDD?
    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
      • May 2011
      • 103
      Re: Ricoh Mp 9000
      hi,
      thanks for response can you please elaborate
      • UNICORNico
        • May 2018
        • 308
        Re: Ricoh Mp 9000
        hi,
        If you are an authorized technician, you will have the corresponding manuals to solve this incident. Otherwise, contact one.
          • 37489
          Re: Ricoh Mp 9000
          Regards
          The 2 HDD on a MP 9000 must be a matched set and replace as such. Both replacement drives must be "NEW' and completely not formatted in any way at all. If either of the drives has been written to by any other system, the 9000 will not recognized and format them.
          • Codex
            • May 2008
            • 704
            Re: Ricoh Mp 9000
            Hello
            Try to swap the HDD's, worked for me sometimes, i experienced that you have to change both discs as a set, happened to me a few years ago, they have to be exact the same
            Memento Audere Semper
            • luca72
              • Oct 2017
              • 1778
              Re: Ricoh Mp 9000
              like mpc3500 two disk! double ball's break!...he can try to connect the two hdd to pc and make low-level format with old pc bios, or some utility
              "I'll be back"
