Ricoh MP C5503 residual images
  • stevewm
    • Aug 2018
    • 5
    I have a C5503 that started printing a residual image (with all colors) of previously printed pages near the bottom of every page. The defect appears approx. 2 inches from the bottom of the page, extending to about 3 inches up from the bottom and does not repeat. This started suddenly; nothing has been changed about the machine, no toner replacements, part replacements, etc... Paper settings are correct.
    I found an old bulletin about ghosting on this series, adjusting the settings as outlined made no difference.
    If I run some blank pages through the residual image will go away, but then return as soon as something is actually printed.
    Any ideas?
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP C5503 residual images
    Can we have a scanned example please?
    Hit it.
    • mikadonovan
      • May 2008
      • 2931
      Sounds like it's time for a fuser rebuild.
      NEVER ASSUME ANYTHING
      • stevewm
        • Aug 2018
        • 5
        Certainly!
        Attached a scanned windows printer test page. The residual image appearing on the bottom of the page is from a previous print job. Those pages where landscape.. The red blob is a logo that appears at the top of every one of those pages. It appears to repeat across the defect.
        • tonerhead
          • Sep 2009
          • 582
          Most likely fuser, could be ITB. You don't sound like a tech. What you are seeing is a thing even a newbie could figure out just by looking at the fuser. If you are a user, consider calling someone to service it.
          I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
          Especially when it comes to sex
            • 37513
            Any ideas?
            Certainly!
            Looks to me like the image does repeat. The paper is Long Edge Feed and I see the same red image 3 times across the page. Looks like a problem with the ITB cleaning unit,
            • stevewm
              • Aug 2018
              • 5
              I suspected fuser, didn't have time to get a good look at it yet. We just got these machines and I am not terribly familiar with them yet.
              Anyways, got time to tear into it. And figured it out. Once I opened up the fuser I could see it plain as day. The receptionist printed some envelopes on it, apparently one of them had the glue flap folded the wrong way. Glue from the envelope transferred to the fuser rollers.
              • tonerhead
                • Sep 2009
                • 582
                Ok, sorry to slam you. Seems like there are getting to be more and more end users looking for free help lately around here.
                  • 37513
                  I would say that the envelopes were not laser compatible. If the flap had been folded the other way the heat of the fusing unit would have sealed the envelope closed.
                  • anothertech
                    • 1771
                    And more and more techs that start asking questions before doing their due diligence.
                    • sandmanmac
                      • 3981
                      That's not slamming.
                      It takes 10 seconds to remove the fuser to at least look at it, before spending 10 minutes to sit down and post a thread about a ROUTINE issue - regardless of experience with ANY Make/ Model
                      • csliao
                        • Oct 2021
                        • 33
                        我有一台 C5503,它開始在每頁底部附近打印以前打印的頁面的殘留圖像(所有顏色)。缺陷出現約。距離頁面底部 2 英寸,從底部向上延伸約 3 英寸,不再重複。這突然開始了;機器沒有任何變化,沒有更換碳粉、更換部件等...紙張設置正 確。
                        我在這個系列中找到了一個關於重影的舊公告,按照概述調整設置沒有任何區別。
                        如果我通過殘留圖像運行一些空白頁,則會消失,但一旦實際打印出某些內容就會返回。
                        有什麼想法嗎?
                         fuser unit 必須 changnge
                        • satins
                          • Feb 2021
                          • 89
                          Certainly!
                          Need to rebuild the fuser and ensure that you use the genuine toner for complete fuser life.
                          • luca72
                            • Oct 2017
                            • 1781
                            Certainly!
                            seem the fuser sleeve that have lost a non-stick coating propriety, in particulary, in that area
                            "I'll be back"
