Ricoh 8100 series counter
  • Naseem
    • Mar 2019
    • 6
    [CQ] Ricoh 8100 series counter
    Hello everyone, I want help in printing the B4 counters and the other counters in the counters list FOR RICOH PRO 8100. Is there a way to print that, thank you
  • Naseem
    • Mar 2019
    • 6
    Re: Ricoh 8100 series counter
    Sorry it has been modified I mean B4 counters not A4
    • dalewb74
      • Feb 2018
      • 1153
      theres that little thing called google....
      • Naseem
        • Mar 2019
        • 6
        Do you have any doubt that I did not ask the little thing called Google before writing the question
          • 37488
          There is also that thing called the Operator Instruction Manual, All the various counters that can be printed are covered there with the exception of those that can be found in the Service Program.
          • Naseem
            • Mar 2019
            • 6
            I want to add information. The machine works on a print card, not a control. The operating instructions were reviewed, but I did not find what was required. Thank you for trying to help me
            • UNICORNico
              • May 2018
              • 308
              You mean you use a "Fiery Controller", correct?
              If it's the case, I at least can't help you, those systems escape my understanding.
              "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
              • Naseem
                • Mar 2019
                • 6
                Do not use "Fiery Controller" Use sd cards to print
                • mikadonovan
                  • May 2008
                  • 2931
                  I do not know about this particular model, but on other Ricoh boxes User tools>system settings>administrator tools>display/print counter. You can also run SMC logging data. The counters will be at the end of the report.
                  NEVER ASSUME ANYTHING
                    • 37488
                    So you are trying to print from a memory card. WHY?????????
                    • Naseem
                      • Mar 2019
                      • 6
                      We are in Egypt canceling the Fiery Controller and using cards that have printing and copying systems
                        • 37488
                        That does not explain why. Memory Device printing is extremely limited in what it can do.
