Ricoh MPC3003 Copy Problem
  • johnCfu
    • Mar 2020
    • 15
    Hi
    I have a ricoh mpc3003 with an amazing problem. When i print a counter the counter perfect with vivid black.
    But when i make a copy of it, its faded grey. I replaced transfer belt, Fuser, drum and also cleaned the mirrors inside the scanner.
    Anyone having an idea of what to do next..?
    Thanks in advance
  • luca72
    • Oct 2017
    • 1724
    Re: Ricoh MPC3003 Copy Problem
    Originally posted by johnCfu
    Hi
    Thanks in advance
    if you have clean well all mirror and glass, run a calibration routine from user tools, check if the client dont have changed default settings in copy application, you can reset this from sp-801-copy application (only copy!!!)
    • StephenB
      • Aug 2015
      • 239
      OEM Toner ? Did you change developer section along with drum ? Did you perform maintenance in user tools (prints and scan adjustments) Do prints, from computer, print solid ?
      Was this your original problem or did this occur after replacing a component ?
      This is either an image creation issue (drum, dev, charge etc) or a copy (scan) problem.
      • DRichard
        • May 2008
        • 482
        Hi
        Thanks in advance
        Laser glass dusted?
        "Enjoy every sandwich."
        -- Warren Zevon
        • Crowfeather
          Printer firmware is !&$!
          • Mar 2021
          • 130
          If you are printing and its perfect, and issue only occurs on copying then the problem is with your scanner, surely?
          They use all the same components and the perfect print indicates the mechanics and electronics on printing is fine.
          Scanning will always be lighter than the original. You can do calibrations on the device to improve quality, there are also some settings that can be changed.
          Do you find that if you scan and then print the scanned image it is also a grey rather than a black?
          • davel
            • Oct 2011
            • 1093
            Clean the entire optics again properly. Why replace fuser and transfer belt?
            • johnCfu
              • Mar 2020
              • 15
              Originally posted by DRichard
              Laser glass dusted?
              everything cleaned up twice glass, laser the entire scan area
              • johnCfu
                • Mar 2020
                • 15
                Already cleaned twice, i changed them just in case.
                • johnCfu
                  • Mar 2020
                  • 15
                  i did the calibrations and its a quite better but not good as a another 3003 that i have next to it.
                  • luca72
                    • Oct 2017
                    • 1724
                    try to update the firmware, and immediately after re-run calibration, anyway could be also the leaky reading sensor...its happen
                    you can try also sp801 scanner, and after copy (not engine, or clear all!!!) keep address book, etc, backup first
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      Swap the K PCDU between them, see if the fault follows it. Could be the dev is a bit tired.
                      Hit it.
                      • tonerhead
                        • Sep 2009
                        • 582
                        Which is better? Copying through feeder or laying on platen glass? Is one acceptable and the other not? Have you tried copying an exposure chart of some sort? Copying the printed out counter page is not a good way to trouble shoot. Have you printed something other than count sheet and something in color?
                        I would tend to lean towards optics like the white plate balance. Are the mirrors ok? Not dislodged? SP4603 might be something to check into.
                        I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
                        Especially when it comes to sex
                        • jermyth
                          Riso dude
                          • Mar 2011
                          • 438
                          Check to make sure you have the grounding plate/cover on the back of the PCDU. I had similar problems with a 2503 to had lost its cover. Black prints were dark, copies were a little light.
                          Good luck.
                          • MIGUELMARCHENA
                            • Feb 2018
                            • 189
                            turn off the machine
                            remove the glass and put a white sheet on top in such a way that when you turn on the machine again, the lamp reads the white of that sheet... put the glass back and try...
                            • Debs1964
                              • Oct 2010
                              • 1687
                              +1
                              Perform SP5-801-006 memory clear for copier application
                              There are 10 types of people in this world, those who understand binary maths and those who don't
