Aficio 2022 light image
  • Gab
    • Aug 2015
    • 670
    I know, i know , it's a very old machine but customer makes about 20-30 copies per day and he need something very cheap.
    The image is ok at the top and bottom but light at the center.
    Cleaned optic, laser unit, laser unit glass slit, separation roller and tried with other drum unit and high voltage board but the same.
    Any idea?
  • GIUBOSS
    • 1392
    Re: Aficio 2022 light image
    Any idea?
    stop the paper before it reaches the fuser and check the quality of the copy
    • StephenB
      • Aug 2015
      • 239
      Can you print from a computer to this ?
      Try to determine if it is a scaning issue or image creation, ie. drum, dev, etc
      I've seen light copy / scan problems from the frame being bent. (Pull up on front left corner to correct)
      • luca72
        • Oct 2017
        • 1748
        Any idea?
        bias conctact or drum ground in machine pcdu slot?
        "I'll be back"
          • 37384
          I would say that it is time to replace the developer.
          • GIUBOSS
            • 1392
            in fact he mentions replaced drum and not PCU ...
            • KeviM
              • Oct 2019
              • 324
              1st thing you need to do is determine if your problem is coming from the optics and lens and SBU board or from your imaging unit, laser unit, etc.
              I would start by doing this: do an internal print. If the machine has the printer interface installed then press, user tools key, printer, list print and print PCL fonts.
              If those are clear and dark then it's most likely a problem with the optics, lens and SBU board. If not then it's most likely laser unit or imaging unit.
              Also How's your fuser unit? Check your rollers
              If you could post a few samples that would be great
              All the best friend
                • 37384
                All the best friend
                If by top and bottom you mean the edges closest to the front and back of the machine, you may have toner scattering on the shield glass. Before attempting to clean the shield glass, remove the PCU and clean all toner that may be piled up against glass. This will prevent it from falling into the laser unit. Also pull the toner bottle tray and check it. If there is a build up of toner in the bottom of the tray replace the tray with a new one. The tray for the MP xx53 series should fit.
                • rthonpm
                  • Aug 2007
                  • 2849
                  What's the quality of the paper?
                  Genuine toner and PCU?
                  Transfer roller been replaced?
                  Toner hopper full of toner or a dirty toner bottle?
                  Sent from my BlackBerry using Tapatalk
