Ricoh opc drum compatibility imc/mpc 3003
  • Pixtech Frameworks
    • May 2020
    • 226
    Hello All,
    I had an opportunity to work for a customer which the ricoh mpc6003 black pcu which was drawing vertical lines due damaged PCR and drum. I found out the drum that came with the printer was a Ricoh imc 3000 opc drum. So how does imc drum fits in to mpc6003.
  • Gift
    • Mar 2011
    • 2444
    Re: Ricoh opc drum compatibility imc/mpc 3003
    I'm afraid not at all - I think the OPC part is the same but the end caps/gears are different
      • May 2020
      • 226
      The end caps of the imc fits into the moc6003. I don't know how they did it. I'll send pictures
      • Gift
        • Mar 2011
        • 2444
        OK - so MPC6003 is different then MPC3003? Didn't know that but we only have a very few MPC6003 out there. I also heard that ricoh did some changes on the drum caps/gears but I recall this for the MPC3004 series.
          • May 2020
          • 226
          A friend of mine told me there a new models of mpc3003/6003. Don't know how true is it.
          • Gift
            • Mar 2011
            • 2444
            It's probably true - ricoh definitely made some changes with the drum/gears, I wasn't shure wich models/series was affected.
              • May 2020
              • 226
              He told me new series of mpc3003/6003. But don't know how to check if its a new or old series.
                • 36831
                Look on the serial number plate for date.
                  • May 2020
                  • 226
                  Thanks Slimslob. I get serial number tomorrow and search online.
                  • UNICORNico
                    • May 2018
                    • 308
                    I think you are referring to this modification. According to the catalog of parts of one of our suppliers.
                    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                      • May 2020
                      • 226
                      [ATTACH=CONFIG]53899[/ATTACH]
                      Yeah. This is it. Pls can I get the English Version of the catalog??
                        • May 2020
                        • 226
                        I have translated using Google translate. Gracias.
                        • luca72
                          • Oct 2017
                          • 1677
                          you can publish the whole sheet please? im curious to read all.
                            • May 2020
                            • 226
                            I've translated to English. Kindly find attached for your reference.
                            • luca72
                              • Oct 2017
                              • 1677
                              Thank you, a good return
