Ricoh mp 4002
  • Transam1
    • May 2011
    • 48
    Ricoh mp 4002
    I have a machine that requires a new hdd does anyone know
    if i need to order from ricoh -Expensive or a comparable laptop hdd will work
    Gary
    • 37628
    Re: Ricoh mp 4002
    Gary
    Look at the label on the old HDD. It should be the original manufacturer's label. Parts catalog indicates a Western Digital WD3200BUCT 320GB drive. Here is the spec sheet. Western Digital WD3200BUCT - HDD FAQs
    • Transam1
      • May 2011
      • 48
      Re: Ricoh mp 4002
      thanks
      • DRichard
        • May 2008
        • 482
        Re: Ricoh mp 4002
        Gary
        You do not need to order from Ricoh. We use HDDs from various sources all the time. Just make sure it is the correct physical size and connector format, and of comparable capacity. Any reputable manufacturer will be okay (we mostly use WD or Toshiba.) Once installed, format it and you're ready to go. I'm sure you will find something that can save you money too.
        "Enjoy every sandwich."
        -- Warren Zevon
        • fbkhan3
          • May 2012
          • 421
          Re: Ricoh mp 4002
          Gary
          Toshiba,Seagate,WD all works , I had no issues using 500gb.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Re: Ricoh mp 4002
            Ricoh is very good about not needing the exact (or almost exact) replacement HDD.
            As long as the basic specs are met, most quality drives will work.
            That is definitely NOT the case with some other brands, who will remain nameless.
            • tonerhead
              • Sep 2009
              • 582
              Re: Ricoh mp 4002
              Begins with a "C" ?
              I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
              Especially when it comes to sex
                • 37628
                Re: Ricoh mp 4002
                I can think of a few Ricoh that did. Factory formatted 2 disk sets that had to be replaced as a set.
                • DRichard
                  • May 2008
                  • 482
                  Re: Ricoh mp 4002
                  True. I would not bother attempting to replace a RAID array with any other than Ricoh OEM. You would just be asking for headaches.
                  -- Warren Zevon
                  • copier tech
                    • 8220
                    Re: Ricoh mp 4002
                    Gary
                    As others have said you can use pretty much any drive.
                    I had a nearly new METIS C1 a few years ago, the standard 320GB HDD failed, I had an old 120GB in the car, had nothing to loose so fitted that, machine prompted to format the drive which I did, after the format machine worked fine so I left it installed.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      Re: Ricoh mp 4002
                      Originally posted by tonerhead
                      Begins with a "C" ?
                      Why yes, yes it does.
                      • Tedstryker73
                        • Jun 2019
                        • 5
                        Re: Ricoh mp 4002
                        Gary
                        Here's a list of compatible HDD's from Hytec...
                        Sales Part No
                        D1425765
                        D1445765
                        M4445201
                        DUNT-9232FCPZ
                        A5URPP0400
                        45114918
                        M4445202
                        M1245765
                        M4445200
                        D7266090
                        D2235307
                        D1465680
                        FE1-6804-000
                        D2235308
                        FE1-6804-00R
                        M4175001
                        D1465690
                        D3GF1020
                        CZ248-67907
                        • GIUBOSS
                          • 1437
                          Re: Ricoh mp 4002
                          I tried once with a 240GB SSD without success, I suspected that ...
                          • UNICORNico
                            • May 2018
                            • 308
                            Re: Ricoh mp 4002
                            We have in some devices, we have installed SSD drives, and at the moment they do not show problems. Did you do all the steps for installation on the machine?
                            "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
