SC120-00 Solution
  • MDR24
    • Apr 2013
    • 64
    [Error Code] SC120-00 Solution
    Hi all,
    I attended a call last week for an MPC2004 giving intermittent SC120-00 (HP Error). After checking motors and sensors in engineers mode, checking drive belts, lubricating rails etc. I removed the scanner drive motor.
    Although it runs correctly in engineers mode about a quarter of the adhesive on the black rubber ring on the motor had come off, causing it to flex a tiny amount. When the scanner unit is moving from right to left at the home position the load must of been just a little to much on occasion which gave the SC120-00 code.
    I'm still pretty new to Ricohs but from what I can tell the IMCs use the same drive mechanism so this may be useful for someone in the future.
    Thanks.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: SC120-00 Solution
    Any chance of a picture of said ring?
    Hit it.
    • MDR24
      • Apr 2013
      • 64
      I've never uploaded an image before, hope this works. I didn't take a photo on site but attached is an image of another motor. I believe it's a rubber for shock absorbing? Its on every motor.
      • GIUBOSS
        • 1435
        I don't remember that ever happening to me, maybe a factory defect, anyway thanks for the tip ...
        • MIKON
          • Jul 2015
          • 187
          They break on the sp5210 all the time
          • emiliorsg
            • Jul 2018
            • 141
            This same failure has happened to me only once with a Brother desktop scanner motor. It must be a factory fault.
