email going out but not hitting in box MP C6004
  • digicor
    • 1152
    the machine says completed... nothing arrives.. I use a go daddy mail svc i have other ricoh c6004s set up no issues.. so i tested it with a port 465 ssl "on" and a .Net set up i have for a private client it works... ends up in spam folder not problem ,,, yadda yadda... but with port 587 no ssl on a .com it leaves the machine and takes a hike through cyber Hills parkway never hitting the mail box... i tried several other port 587 no ssl ,,, with ssl ,,,port 465 on a .com no luck
    i lowered the security to 0 no luck...
    authentication is on
    anyone ever have had this problem? and what my be the fix?
    Thank for any suggestions
    • 37052
    Re: email going out but not hitting in box MP C6004
    By .com are you referring their Office 365 email server? Here is the link to their support file. Security check
    You may also need to search Microsoft's Office 365 support document.
    • rthonpm
      • Aug 2007
      • 2847
      If it's an Office 365 account, make sure that SMTP AUTH is enabled for the sending account.
      Sent from my Pixel 6 Pro using Tapatalk
      • digicor
        • 1152
        authorization is enabled
        • justanotherhack
          • Apr 2015
          • 74
          Is there a subject, and something in the body of the email? Also, is the time correct on the MFP?
          • digicor
            • 1152
            the time on the MFP is 8:45am but it was acually 10:45 am now that you mention it,,,, hmmm what would this do to the out going mail being sent?
            yes there is subject text not sure about body i think so ... yes there is text in the body message
              • 37052
              Check the time zone that the C6004 is set for. If 8:45 was the correct time for the set time zone, no problem. On the other hand having the time zone correct and the time wrong can make the server think it is malware and dump it.
                • 8120
                Have you tried sending email to various different addresses? will it send OK to any domain ?
                • digicor
                  • 1152
                  i send it to many different domains same result
                  • digicor
                    • 1152
                    im visiting the client tomorrow and will check out this time variation may be the cause... i will post a response
                      • 37052
                      What if you send to the same domain as the authentication email address. If it goes through then it would appear that your customer is setup to use Option 2 of the following link. If the C6004 is not properly supporting TLS/StartTLS then they may have to use Microsoft's relay server, Option 3 of the following link.
                      Warning: Much of what is discussed in the following link, especially Option 2 and Option 3 should be done by the customer's IT. If you are not the customers IT, getting it working is not your responsibility. Provide the link to the customer or their IT and let them handle the setup.
                      How to set up a multifunction device or application to send email using Microsoft 365 or Office 365 | Microsoft Docs
