Clear copy in MP2501SP
  • tullio
    • Feb 2012
    • 268
    Dear all,
    i replaced the complete kit (drum, developer, cleaning blade, charge roller, hot roller, pressure roller, thermistors) after completing its life, before replacing parts copy quality is light and after replacing parts the problem is always the same,
    there is a lot of off-background in copy.
    print is ok -
    the print is beautiful black.
  • Gift
    • Mar 2011
    • 2459
    Re: Clear copy in MP2501SP
    Dear all,
    print is ok -
    If prints from PC or internal pages like counter list looks fine it must be scanner related. Try and clean the scanner + mirrors and check the scanner/ccd SP data if they match witht he values from the birth sheet.
      • 37556
      Always the first thing to do for light copies when prints are good.
      • KeviM
        • Oct 2019
        • 327
        Dear all,
        print is ok -
        Like the other techs mentioned, do and internal print and check quality.
        Also!
        Are all parts replaced original? Generic can cause issues.
        Have you checked the toner? Toners can give you issues as well. Is it original? Was it changed?
        Have you initialized the unit after putting in all the new parts?
        Run some prints / copies then check your VGS, VT, VTS. Make sure all is within range
        • luca72
          • Oct 2017
          • 1791
          Dear all,
          print is ok -
          Hi Tullio, the problem is, how much clearer the copy is, compared to the prints, I would advise you to give the optics a good clean first, and then a clean inside the laser box, simple and fast operation (it takes 10 minutes)
          check that the customer has not memorized particular default image settings in the copy screen, if still clear, try to reset only the sp 5-801-copy application, and update the firmware, if the problem persists, it could be the sensor at a loss.at this point, instead of replacing it, remove "auto-density", gradually darken the copies with the cursor until it seems ok.
          At this point, store the condition using the "memory" button on the display, making this, in fact, the default condition
          "I'll be back"
          • fbkhan3
            • May 2012
            • 421
            Dear all,
            print is ok -
            Change the Development bais to -650.
            It should print and copy like charm,i have done this on dozens of 2001 and 2501 machines for this background issue and never had any issues after that.
            Good luck.
              • 37556
              Good luck.
              Only if SP 3041-001 is change from the default of 1 to zero. Otherwise the value computed by Procon will be used.
              • tullio
                • Feb 2012
                • 268
                toner is original. the laser has been cleaned.
                • fbkhan3
                  • May 2012
                  • 421
                  To be honest i don't think there are any group 3 SP modes for this machine.
                  • dalewb74
                    • Feb 2018
                    • 1162
                    hopefully the copy isn't a copy of a copy. just throwing that one out there....
