MP2555 SMB scan portrait or landscape question
  • copyaction
    • Oct 2007
    • 991
    • 37556
    Re: MP2555 SMB scan portrait or landscape question
    Sounds like someone changed a setting at the control panel.
    • copyaction
      • Oct 2007
      • 991
      That is what I thought and I checked the settings and it is on Auto Detect.
      Not sure if there is something else.
        • 37556
        Originally posted by copyaction
        That is why I thought and I checked the settings and it is on Auto Detect.
        Auto rotate
          • 23010
          AFAIK there are two main possibilities:
          -The endusers inconsistently load their originals LTR or LTR-R, or inconsistently setting the original width guides, and expect the machine to just "...figure out the right way for it to display."
          -Some or all of the information they are providing you with is false.
          Either way, unless they can DEMONSTRATE the issue, it's probably operator error. =^..^=
          • Gift
            • Mar 2011
            • 2459
            AFAIK enabled OCR can also mess with the orientation
            • KeviM
              • Oct 2019
              • 327
              Hello
              You need to check the settings. Most likely it's been changed. Correct it and set as new defaults
              Best of luck friend
              • copyaction
                • Oct 2007
                • 991
                Originally posted by KeviM
                Hello
                You looking for this [ATTACH=CONFIG]54225[/ATTACH]
                Best of luck friend
                Thanks, it is set to Readable direction but makes no difference.
                • KeviM
                  • Oct 2019
                  • 327
                  I would say if the orientation is set to the right direction and if when you are running scanning tests the scans are coming in the right direction in the folder then it's 1 of 2 things
                  1) it's user error. Possibly 1 of the users are not using the machine correctly.
                  Maybe print out a note and stick it on the machine. Detailing how to scan and how insert originals with a diagram of the original direction and direction of writing.
                  2) Firmware faults. Try a firmware update
                  Also: try sticking around at the customers place for about an hour or two just to observe how they are using the machine.
                  And
                  Give them a tutorial again on how to use the machine. Shocking how many times I've given customers tutorials on how to use their machine. Even after having their machine for more than 4 years some of them still don't know how to load paper properly.
                  And
                  In an office with multiple users, someone can be new and not know how to use the machine.
                  Lastly: is scan to email also doing the same thing?
                  • copyaction
                    • Oct 2007
                    • 991
                      • 37556
                      I wonder, could it be something only available when the scan to OCR option is installed? Determining readable orientation would necessary for OCR conversion.
