RICOH 9100 - sc590-36
  • mar
    • Dec 2021
    • 8
    [Error Code] RICOH 9100 - sc590-36
    Ricoh boots with sc590-36 error. What is this error about?
  • bat
    • Sep 2008
    • 140
    Re: RICOH 9100 - sc590-36
    Paper Transport Motor 2 Error
    Motor driver IC error has been detected. Always monitored except when
    a cover is open.
    1. Connector disconnected
    2. Harness broken or shorted
    3. Motor defective (motor coil broken or shorted)
    4. PCB defective
    1. Reconnect the connectors between the motor and IOB2 (including
    relay connectors).
    2. Replace the harness between the motor and IOB2.
    3. Replace the motor.
    4. Replace IOB2.
    • anothertech
      • 1771
      Check out this pub. it's for C9200 but might apply to the C9100 too.
      RTB No._ RM0B1169a _ The harness between IOB2 and PFB2 may break when installing the rear low co.pdf
      • Sashko
        • Oct 2009
        • 110
        You have two ways for solve this issue:
        1 - replace IOB2 (part number is M2055329)
        2 - replace the relay FTR-K2AK005T on IOB2 PCB in the exit unit
        Second way is not easy but is cheaper.
