SC-672-11 mpc 2003
  • joserf
    • Feb 2019
    • 24
    #16
    Re: SC-672-11 mpc 2003
    Hi Luca, I tried what you told me about the switches and nothing. Then I tried to clean the entire plate and neither. Regarding the hard drive, I will keep it in mind for future plates.
    • joserf
      • Feb 2019
      • 24
      #17
      This is what I mean but for the 2003 mpc. I would only need the procedure
      Boot SD Card - rfg022454[1].pdf
      • joserf
        • Feb 2019
        • 24
        #18
        Froced System x.pdf
        I do not have access to that platform, if someone could access
        • luca72
          • Oct 2017
          • 1781
          #19
          [ATTACH]54514[/ATTACH]
          i understand, this pdf its for old machine, on this series you must copy only "systemcopy" on sd card, in romdata folder, but i dont remember the key sequence thet you must push when power up the machine, you securely found this here on some thread, in particulary i remember time ago, a post of the user Debs1964 that which explained well how to do it , maybe someone remembers better than me(?)....It might work
          "I'll be back"
          • joserf
            • Feb 2019
            • 24
            #20
            [QUOTE=luca72;2202691]
            • luca72
              • Oct 2017
              • 1781
              #21
              [QUOTE=joserf;2202709]im intend "[reset] 143 C+C+C (keep press until the beep) " , then reboot with the SD card still in the device with only systemcopy, it should update system/copy and come ready
              "I'll be back"
              • joserf
                • Feb 2019
                • 24
                #22
                Could someone get me this file?
                  • 37510
                  #23
                  [ATTACH=CONFIG]55417[/ATTACH]
                  Google panasonic sd card format tool
                  • joserf
                    • Feb 2019
                    • 24
                    #24
                    Sorry, I mean the file B2215601F_1
                      • 37510
                      #25
                      What makes you think that you need an old firmware version. Any correction made by that version would also be included in all later versions of which there at least 11. Do you even know what your current firmware level is?
                      • joserf
                        • Feb 2019
                        • 24
                        #26
                        My goal is to do this process on the mp c2003. I have the firmware but I don't have dummy48.pat 1dinstall sistem.rom and install.cnf
