Ricoh MP C307 screen HS ?
  • Bourriks
    • May 2016
    • 38
    [Misc] Ricoh MP C307 screen HS ?
    Hello Everyone. Some colleagues had to switch the OP screen on a old MP C307 to resell it. The old screen was scratched.
    The screen was correctly replaced by a colleague last week. Today, another colleague was to finish the job and saw the screen cover was not on. He just re-dismounted the screen to correctly replace the covers, and since then, the screen does not start. Even the power led doesn't light.
    Helping him, I tried 2 other screens, with the same result. I even grabbed anothe USB cord from a broken machine (I wondered if the cord was not over-folded in the process of replacing the cover), but without result.
    The onlu thing left wold be replacing the engine board, but I find this weird for a machine who worked fine 2 hours ago and whose the covers have been replaced.
  • luca72
    • Oct 2017
    • 1748
    Re: Ricoh MP C307 screen HS ?
    something are happened, try to check the welds around the usb connector on the BICU drive board, and the LCD, and the input voltage on LCD, from board, it would seem power problem(?)....if you have sop, check the attachment!
    "I'll be back"
    • copier tech
      • 8131
      Why did your first colleague only half fit the screen requiring another engineer to finish the job?
      Is the machine now totally dead no power LED on at all ?
      • Gift
        • Mar 2011
        • 2458
        If nothing works I'd go with the scratched but funtional panel to see f it works again and as a final fix swap out the digitizer taken from the dead panel
        Hard to tell what happened, it's either a cable/connection issue or the PCB that hold the USB connector got too much tension during handling or something electrostatic fried the PCB.
        • TonerMunkeh
          Professional Moron
          • 3865
          I've had people put the wrong screws in the wrong place when replacing a panel, some of the screws are a lot longer than others and panels have been blown because of it.
          Hit it.
          • Bourriks
            • May 2016
            • 38
            Hello everyone.
            I found a functionning MPC307 to plug the screen on, and the screen works fine. Even with a spare USB cable I picked on another dead copier.
            The issue is on the engine board. It works on the copier parts (I can hear the fans and the correct motions of fusing and PCU), but does not inject electrical power on the screen. The machine has been placed for spare parts, it's too expensive to change the engine board.
            Thank you for your answers.
