Ricoh 7503 code 14 jams.
  • Free-coh
    Ricoh Production Tech.
    • Apr 2015
    • 38
    First time seeing this particular machine but have been servicing them for years. PCU bound up due to recycle tube shutter mistakenly left closed (I didn't do it!) lol...anyway, replaced lower drum unit now I am getting frequent code 14 (fusing unit exit late). Steps taken, cleaned registration sensor, relay sensor, regis. roller. Sometimes sheet makes it into fuser, sometimes ends up on top of duplex unit? strange. duplex mode is even worse...I am suspecting transfer belt either slipping drive or worn out to the point of not attracting paper. PM counter reads 840k on belt but we inherited machine so not sure. ordered belt and blade but would like to hear some opinions on this...TIA.
    • 37628
    Re: Ricoh 7503 code 14 jams.
    Should also replace discharge plate and transfer cleaning roller. One other thing, fusing exit sensor are known for hysteresis problems as they age. Both reed switches and photo interrupters will eventually get to where they delay changing state when hot. It is only a few milliseconds but enough to be read as a jam.
    • TonerMunkeh
      Professional Moron
      • 3865
      Depending on the mileage of the machine the registration mylars could also be knackered.
      Hit it.
      • MIKON
        • Jul 2015
        • 191
        I would check drum pick off claws and transport belt
        • luca72
          • Oct 2017
          • 1792
          Isn't it that someone has mounted the transfer unit with the lifting lever upside down? look on another martini, if by operating the blue lever, it goes up in the direction different/overturned from yours
          "I'll be back"
          • Free-coh
            • Apr 2015
            • 38
            Just got back to this machine...Replaced transfer belt and blade and set all voltages to the paper chart specs included with belt. No go! still jams and now output is very light in areas. Lucky enough to be able to ensure it is in the belt unit by temp. swapping it with same model machine and quality looks great. Ordered Transfer unit power pack and harness.
