First time seeing this particular machine but have been servicing them for years. PCU bound up due to recycle tube shutter mistakenly left closed (I didn't do it!) lol...anyway, replaced lower drum unit now I am getting frequent code 14 (fusing unit exit late). Steps taken, cleaned registration sensor, relay sensor, regis. roller. Sometimes sheet makes it into fuser, sometimes ends up on top of duplex unit? strange. duplex mode is even worse...I am suspecting transfer belt either slipping drive or worn out to the point of not attracting paper. PM counter reads 840k on belt but we inherited machine so not sure. ordered belt and blade but would like to hear some opinions on this...TIA.
Ricoh 7503 code 14 jams.
Re: Ricoh 7503 code 14 jams.
First time seeing this particular machine but have been servicing them for years. PCU bound up due to recycle tube shutter mistakenly left closed (I didn't do it!) lol...anyway, replaced lower drum unit now I am getting frequent code 14 (fusing unit exit late). Steps taken, cleaned registration sensor, relay sensor, regis. roller. Sometimes sheet makes it into fuser, sometimes ends up on top of duplex unit? strange. duplex mode is even worse...I am suspecting transfer belt either slipping drive or worn out to the point of not attracting paper. PM counter reads 840k on belt but we inherited machine so not sure. ordered belt and blade but would like to hear some opinions on this...TIA. -
Depending on the mileage of the machine the registration mylars could also be knackered.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
First time seeing this particular machine but have been servicing them for years. PCU bound up due to recycle tube shutter mistakenly left closed (I didn't do it!) lol...anyway, replaced lower drum unit now I am getting frequent code 14 (fusing unit exit late). Steps taken, cleaned registration sensor, relay sensor, regis. roller. Sometimes sheet makes it into fuser, sometimes ends up on top of duplex unit? strange. duplex mode is even worse...I am suspecting transfer belt either slipping drive or worn out to the point of not attracting paper. PM counter reads 840k on belt but we inherited machine so not sure. ordered belt and blade but would like to hear some opinions on this...TIA."loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)Comment
Just got back to this machine...Replaced transfer belt and blade and set all voltages to the paper chart specs included with belt. No go! still jams and now output is very light in areas. Lucky enough to be able to ensure it is in the belt unit by temp. swapping it with same model machine and quality looks great. Ordered Transfer unit power pack and harness.Comment
