Gmail Scanning 2352
  • SBenda
    • Apr 2019
    • 11
    Gmail Scanning 2352
    Anyone know if you can scan using smtp.gmail.com port 587 to a 2352? I see that 'Allow Less Secure Apps' is no longer an option in Google Security settings.
    • 37491
    Re: Gmail Scanning 2352
    Here is thew latest from Google Support. You will notice that you need to sign to your Google Admin Console. This means the administrator for the company's Google Work Space Account, formerly Google Doc account.
    Send email from a printer, scanner, or app - Google Workspace Admin Help
      • 30219
      You have to turn on 2 factor than setup an apps password
        • 37491
        Are you suggesting that Google Support does not know what they are talking about when it comes to gmail?
        • sandmanmac
          • 3981
          Tim, I have to concur with bsm2.
          2FA must be enabled and an App password created is the only way I know of to authenticate with an MFP since "Less secure Apps" was removed.
          Same applies to Yahoo as one other example.
            • 37491
            In setting up Google relay service, one of the authentication options is IP address. This would be the Public address of the customer's internet modem. One thing, this does not apply to free gmail accounts and there are limits on how many emails can be sent a day.
            • SBenda
              • Apr 2019
              • 11
              Thanks! So I just generate an app password and use that to authenticate on the copier side? Still using same smtp.gmail.com and tls?
              • sandmanmac
                • 3981
                I'll take this one......yes
                • luca72
                  • Oct 2017
                  • 1779
                  I did it two months ago, but I already forgot everything ... SOB!
                  "I'll be back"
