C2003 overtoning
  • joelcarrara
    • Jan 2017
    • 47
    C2003 overtoning
    Hello...We are primarily Konica Minolta repair but have a client that has a few legacy Ricoh MP C2003. Having an issuing with the yellow overtoning all all prints/copies. We've replaced the drum and dev and reset the voltage in the SP2-005-238 to what is specified on the drum. We've done a color calibration and have looked in the service manual but no luck..any suggestions? Thanks!
    • 36890
    Re: C2003 overtoning
    When you replaced the "drum and dev" did you install a complete PCDU either from Ricoh or from a quality distributor such as Precision Roller? Or did you replace just the drum and developer powder form some Chinese company like Alibaba?
    • joelcarrara
      • Jan 2017
      • 47
      good question. All oem from precision and replaced both at same time.
        • 36890
        Did you set SP 3701-071 to 1 before replacing the Y drum and SP 3701-072 to 1 before replacing the Y development unit? If not, the value entered in SP 2005-238 most likely did not get loaded to the engine. Do so now, reenter the value from the PCU sticker into SP2-005-238 and cycle the power off and back on. That number is a correction number for the toner density sensor. SP 3701 also resets the PM counters for you.
        • joelcarrara
          • Jan 2017
          • 47
          • GIUBOSS
            • 1382
            To avoid damage and above all not to make a bad impression with the customer, next time I suggest you ask for suggestions before getting your hands on these machines, good luck.
            • luca72
              • Oct 2017
              • 1686
              there is a sheet inside a pcu box, that explain all procedure and system SP to perfect install part, do not reset both parts at the same time, first reset one, then restart, and reset the other, and restart the machine, then check the reset in the pm counters, replacing those developer unit + pcu, you will solve that problem .... ah ... clean the sensors id and do the calibration from user tools at the end
              • UNICORNico
                • May 2018
                • 308
                I have a doubt Luca.
                Why do you recommend making unit adjustments at different times?
                Any calibration issues?
                In my experience, I have not seen short- or long-term problems. You've left me intrigued.
                "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                • joelcarrara
                  • Jan 2017
                  • 47
                  I'm happy to report that your suggestions worked and we now are printing ok and yellow overtoning is a thing of the past. Thanks to all for your help! Much appreciated.
                  • luca72
                    • Oct 2017
                    • 1686
                    If you reset both in same time, happen that if you go to check, you will notice that the pm of the developer unit is reset, the pcu no, regarding the calibration, I think that the value to be entered is a only "fine adjustment".
                    Anyway, i do a complete calibration at the end of maintenance,
                    • luca72
                      • Oct 2017
                      • 1686
                      On model with more costous developer unit, like 3003, you can replace only the developer powder, i put It the MPC 2500 developer powder in the my mpc6003 dveloper unit, with overtoner, and work great, but i must add a bit of old powder mix because the MPC 2500 box have minor quantity
