mpc307 waste toner
  • AMS
    • Jun 2017
    • 73
    mpc307 waste toner
    I have one the says waste toner almost full to call service. I replaced the disposal tank but the message does not clear. I reset the pm counters. Cleaned the sensor. I blocked the sensor with paper and it did not read full. I am not sure if it says full right away or after a few copies. I am guessing it says near full by a copy count. Any suggestions would be welcome before I change out the sensor and update firmware. I never have had this problem before. Thanks
    • 37491
    Re: mpc307 waste toner
    It could be a defective waste toner bottle set switch.
    • copier tech
      • 8145
      Check the waste toner full sensor operation using input check in SP mode.
      Also seen the flag knocked off the bottle or packing tape still attached.
      • TonerMunkeh
        Professional Moron
        • 3865
        You have to do 3701 for the waste tank to make the message go away. More Griffin stupidity.
        Hit it.
        • copier tech
          • 8145
          The waste toner is a consumable item the customer can not use an SP mode to reset!.
          • AMS
            • Jun 2017
            • 73
            went back and updated firmware and replaced sensor and it took care of it. I did both at the same call so I am not sure which one actually fixed it. I am just happy it finally reset.
