SC 502. Mpc407
  • Bicyclerepairman
    • 63
    [Error Code] SC 502. Mpc407
    Optional tray 2 for this machine codes out when paper level gets low. Fully loaded will lift and display paper set. With maybe 1/4 full it will lift but code out with 502.
    Have replaced tray, which is only plastic part, had to transfer hardware fron original tray. Replaced lift motor , ,sensors on rear of machine that tray flags, and pcb controller. TIA.
    • 37052
    Re: SC 502. Mpc407
    SC 50X normal has to do with the tray lift motor where X is the tray with the problem.
    • Jonoharris
      • Sep 2017
      • 1
      • Bicyclerepairman
        • 63
        Re: SC 502. Mpc407
        Not yet!
        • adween shaari
          Senior IT Technician
          • May 2012
          • 47
          Re: SC 502. Mpc407
          Try to remove the tray and check if have any paper was stuck inside at the tray lift motor.
          Sent from my JNY-LX2 using Tapatalk
          • copier tech
            • 8120
            Re: SC 502. Mpc407
            Wrong machine & I suspect this was the first thing he checked.
