Ricoh Pro C5310 Faded/light prints or copies
  • Babujoseph
    • 35
    Ricoh Pro C5310 very faded/light copies all color, replaced all drum and developer, ITB assembly, transfer unit. looks like an image from ITB, the image is not getting transferred to the paper please advise me. Meter count 20k color 22k black. enclosed a sample copy
  • Sashko
    • Oct 2009
    • 110
    Re: Ricoh Pro C5310 Faded/light prints or copies
    Looks like the bad NVRAM on the controller board.
    Try to print the test page from Printer SP mode SP1-103-002 Color Chart
    Please send scanned image of the printed pages.
    • kevslane
      • Mar 2017
      • 24
      Are you using the paper catalogue, I've had issues where this was corrupt causing similar issues?
      Sent from my SM-A526B using Tapatalk
      • Babujoseph
        • 35
        It's fixed was an easy fix finally
        • copier tech
          • 8132
          After you replaced ALL the drums, developer, ITB ass'y, & transfer unit what was the 'easy fix?'
          • Babujoseph
            • 35
            I downloaded the NVRAM onto the SD card. And cleared the NVRAM and uploaded the NVRAM from the SD card to the copier back.it fixed the problem. All good
            • gilbert
              • Oct 2017
              • 38
              You download the NVram into an SD card from which site?.
              please explain briefly
                • 37412
                From the C5310 to the SD card. Instructions are in the service manual. If you do not have or cannot understand the service manual, you should not be even trying to work on a Production machine.
                • Morse
                  • Oct 2021
                  • 5
                  Drum nicks
