RICOH MPC 307
  • esvesdin
    • Mar 2022
    • 22
    #16
    Re: RICOH MPC 307
    Originally posted by anothertech
    Look in User tools, Machine settings, Printer. There is a setting in there that can be set to one sided or two sided.
    I check that setting it is o.k that not the issue here .
    greetings
    • keithxxiii
      Just a tech
      • Nov 2014
      • 471
      #17
      Re: RICOH MPC 307
      Have you tried printing configuration page and see the behaviour of it? If it is the same, then must be from the printer. Maybe an SP mode or a Bit Switch.
      Aye! Cut the crap
      • esvesdin
        • Mar 2022
        • 22
        #18
        Re: RICOH MPC 307
        yes test page also make two passes
        wich bit switch did you mean?
        greetings
          • 37652
          #19
          Re: RICOH MPC 307
          What is SP 5807-001 set to? It should be 3 for Europe. In some Asian countries they duplex everything.
          Also check SP 5195-001 is set to 0. Set to 1 could cause face up exiting.
          • esvesdin
            • Mar 2022
            • 22
            #20
            Re: RICOH MPC 307
            in my case exiting face down
            greetings
            • zeeaxis
              Manager TSD
              • Nov 2008
              • 28
              #21
              Re: RICOH MPC 307
              Originally posted by esvesdin
              Hello my printer ricoh mpc 307 , always makes two passes even though I give him one-sided printing
              any idea ?
              New Ricoh PCL6 drivers have a flaw. When you install a new driver, the duplex is by default enabled to print and flip on long edge. This is standard since Ricoh's xx02 series.
              The solution is that after installing the driver you need to go to
              Control Panel > Printer Properties (right click on your device) > Advance Tab > Printing Defaults > Detailed Settings Tab > Edit (From Menu) > 2 Sided (select Off from drop-down choices) > Apply > OK
              and you are good to go.
              • tonerhead
                • Sep 2009
                • 582
                #22
                Re: RICOH MPC 307
                A little late to the dance, but I've found that sometimes you need to turn off duplex in BOTH printing defaults and printing preferences on the print driver. The other thing is sometimes an app will over ride the print driver. I believe Adobe Reader is one that does.
                I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
                Especially when it comes to sex
                • sandmanmac
                  • 3990
                  #23
                  Re: RICOH MPC 307
                  Just wondering if the original poster has found the solution to this because it sounds like I may have run across the same situation with an MP C3004, so I'm withdrawing my earlier "Strong stance" that it MUST be a driver issue
                  Full disclosure, I was just contacted by a colleague who sold this machine recently, but does not do Service or IT (long story, that I won't waste time on).
                  Apparently the machine is printing double-sided all the time regardless of the setting just as described at the start of this thread.
                  We went through all of the usual things over the phone, and then he mentioned that they have a MAC that does the same thing, which sort of changed everything in my mind, and indicated that it probably is something a little unusual in the machine settings
                  I'm planning on visiting the site with him early next week, and just thought I'd reach out for some further input if anyone had any.
                  I feel that if there's nothing obvious once I get there, I'll go about do a memory reset on all the printer related items
                  • sandmanmac
                    • 3990
                    #24
                    Re: RICOH MPC 307
                    I thought I'd at least update my findings, since the original poster has gone MIA.....what a surprise!
                    I've resolved the situation for my colleague, and it was pretty simple...although I learned some things to save in my 'Data bank'.
                    As I expected, the driver had just been auto installed with Windows, and while WSD had been disabled by the previous owner (I assume), it was installed using the IPP port - which is another port that I don't fully understand, but I just know that it's damn awful when a (Ricoh) device is installed on it.
                    I always use the full PCL6 driver package on the TCP/IP port when I setup my systems, and it would seem that when that's done, it will override many settings on the machine, so the issue was resolved
                    It seems that no matter what you do when the printer is installed on the IPP port (and possibly the WSD port) some machines settings settings will take precedence of the the driver properties.
                    So, it was after I straightened out their half dozen or so laptops, that I went to the MAC and saw that it was doing thew same thing and that's when I disabled Duplexing in the printer settings on the machine and it was sorted out
                    Props to Tonerhead for that tip!
                    • esvesdin
                      • Mar 2022
                      • 22
                      #25
                      I find solution of this problem , I find in PRINTER SP under the nomber 1001 , one bit switch is selected to 1 ( i put on 0 )
                      tnx a lot everyvone
