RICOH MPC 307
  • esvesdin
    • Mar 2022
    • 22
    RICOH MPC 307
    Hello my printer ricoh mpc 307 , always makes two passes even though I give him one-sided printing
    any idea ?
    • 37628
    Re: RICOH MPC 307
    Check to see if there is a setting for Face Up Exit. It will cause the machine to send the copy through the duplex unit to turn it face up.
    • esvesdin
      • Mar 2022
      • 22
      Re: RICOH MPC 307
      no exiting face down
      greetins
      • emiliorsg
        • Jul 2018
        • 141
        Re: RICOH MPC 307
        The default printer driver comes double-sided. Change it.
        • esvesdin
          • Mar 2022
          • 22
          Re: RICOH MPC 307
          i change default printer to one side print that isnt the issue here
          greetings
          • anothertech
            • 1771
            Re: RICOH MPC 307
            How does it work when you make a copy?
            • esvesdin
              • Mar 2022
              • 22
              Re: RICOH MPC 307
              in copy mode it works fine. The copy does not go to duplex.
              greetings
              • sandmanmac
                • 3990
                Re: RICOH MPC 307
                greetings
                100% this is driver setting issue. Figure it out. You're missing something. It's not the machine.
                I've never, ever, heard of some other reason for this behavior
                Anyone else?
                • tsbservice
                  Field tech
                  • 8064
                  Re: RICOH MPC 307
                  And what about kind of driver/connection? WSD install is always bad.
                  Use appropriate Ricoh driver for model and connectivity.
                  • esvesdin
                    • Mar 2022
                    • 22
                    Re: RICOH MPC 307
                    Anyone else?
                    It's not driver , I checked everything in detail and I'm using PCL 6 for a very long time so I'm pretty sure it's not driver
                    greetings
                    • esvesdin
                      • Mar 2022
                      • 22
                      Re: RICOH MPC 307
                      connection is by IP adresss i'ts not by WSD Port and driver is PCL 6 from ricoh page
                      greetings
                      • tsbservice
                        Field tech
                        • 8064
                        Re: RICOH MPC 307
                        greetings
                        OK then I would probably do some machine reset, just in case.
                        • sandmanmac
                          • 3990
                          Re: RICOH MPC 307
                          greetings
                          I'm standing my ground.
                          Try removing the driver....and entire driver package. Reinstall, and reconfigure.
                          The issue is on the PC end.
                          Have you tried another PC/ laptop or even your phone?
                          Heck, even Try a totally different driver. For example, PCL5c or even one for another machine like MP C305 or C306 (It's all PCL after-all)
                          • anothertech
                            • 1771
                            Re: RICOH MPC 307
                            Look in User tools, Machine settings, Printer. There is a setting in there that can be set to one sided or two sided.
                            • esvesdin
                              • Mar 2022
                              • 22
                              Re: RICOH MPC 307
                              I tried from another computer , even with another O.S. ( win 7 and win 8 )again the same , problem is there.I like the idea of an older driver and mobile aplication . I'm gona test it on monday olso I'm going to try with universal driver or maybe to see if there some firmweare update
                              greetings
