MPW 5100
  • leprosydog777
    • Jan 2018
    • 33
    MPW 5100
    Hello i have a ricoh mpw5100 runs fine for a while than has sc406 and add toner problem i replaced id sensor drum drum blade and dv still after runs for a while continue has sc406 seen flow on dv build up on the left side so clean adj doctor blade still has problem any ideas
    • 37491
    Re: MPW 5100
    Have you checked that the machine is setting level?
    • leprosydog777
      • Jan 2018
      • 33
      Re: MPW 5100
      absolutley i even raised the left side to even out
      i also check doctor blade height level to have even flow of dv
      when cheat door and watch toner flow even across except left side
      • leprosydog777
        • Jan 2018
        • 33
        Re: MPW 5100
        the problem was new dev unit never heard back
