Ricoh MP4054 Waste Toner Buildup in Drum Unit
  • laser801
    • May 2014
    • 151
    Hey folks, I am experiencing many instances lately on different machines where the Drum Units build up waste Toner and start leaking down all over the transport as well as in the trays... I have replaced the Drums and it would come back after a while... Has anyone had issues with the waste toner auger system??? The Waste Toner Containers seem to be getting toner in...Any Bulletins on this??? Thanks in Advance, Laser801
  • emiliorsg
    • Jul 2018
    • 141
    Re: Ricoh MP4054 Waste Toner Buildup in Drum Unit
    It happened to me in a machine, I think I remember, a gear or some element of the toner recycling set in the attached image broke and residual toner accumulated in the pcu. I can't remember exactly what it was.
    • dalewb74
      • Feb 2018
      • 1159
      sounds like the auger in the back. this is a known issue.
      • laser801
        • May 2014
        • 151
        [ATTACH=CONFIG]55464[/ATTACH]
        Thanks for your help... I just found a Bulletin too!
        • laser801
          • May 2014
          • 151
          • UNICORNico
            • May 2018
            • 308
            Does the toner conveying system in the Drum Unit rotate correctly?
            On a visit I found something similar and it turned out that the unit did not transport the toner correctly, accumulating it, and that is why the gear was in poor condition.
            mpc4503.jpgMPC4503
            The strange thing is that in Series 04, these references do not appear. So there are 2 possibilities:
            - Improved performance and durability.
            - They do not want to replace these parts and are forcing the replacement of the Drum Unit.
            SORRY: I just realized it's a monochrome model xD lol
            "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
            • luca72
              • Oct 2017
              • 1786
              it happened to me 6-7 times, but it was always and only the toner screw broken at the end, for the rest, I always checked both the gear and the toner recycling system with its rotating solenoid, but it didn't work for me never happened that they were broken
              "I'll be back"
              • sandmanmac
                • 3982
                I feel you.....I can't tell you how many times I've done the same thing myself!
