Ricoh MP201 not fusing and ghosting
  • tsbservice
    Field tech
    • 7976
    Hi team. Not Ricoh trained but have manual.
    The problems described, machine counter is low only 50k fusing unit looking good at first sight (but not removed from machine) drum unit was changed together with OEM toner (they used compatible before). Can't see any fuser temperature adjustment in manual. As per ghosting issue it's with circumference 25 mm which I guess may be drum cylinder?
    Anyway this is at random/side client for us but we would like to fix it although no spare parts/machine is available.
    Any ideas from experienced would be greatly appreciated 👍
  • emiliorsg
    • Jul 2018
    • 141
    Re: Ricoh MP201 not fusing and ghosting
    From my experience it is usually a fuser problem. You can change the fusing temperature with sp1105 mode.
      • 37360
      Check that the surface of the hot roller has not become coated with toner as that will cause fusing unit offsetting.
      • DRichard
        • May 2008
        • 482
        PM interval for this is 90k, but that assumes several variables are all on the money, not the least of which is the using of Ricoh toner. Your hot roller is probably the culprit.
        "Enjoy every sandwich."
        -- Warren Zevon
        • GIUBOSS
          • 1385
          Extract the fusing unit, move the two side levers to bring the rollers together and check if the pressure roller presses the fuser well as the two bushings mounted on the end can be worn as well as the fuser roller outside of the PM counter.
          • MIKON
            • Jul 2015
            • 186
            Also check the guide plate H5562206 if the ends break it will cause the fuser to not tighten
            • tonerhead
              • Sep 2009
              • 582
              Is the offset only on onesies? Long runs are ok? You might need to do sp1103 and turn on fuser idling. My bet is on the pressure roller bushings as was mentioned since you think the heat roller is ok. If you want to save parts, I have folded paper I forget, 2-4 layers thick and have put it between the pressure roller and the bushings when I was in a bind. That worked perfectly until I got the bushings. I was tempted to just leave it, but since I now had the bushings, I replaced them.
              I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
              Especially when it comes to sex
              • StephenB
                • Aug 2015
                • 239
                make a copy, open door to stop the paper feed before it gets to the fuser.
                If you have ghosting, problem is PCU related,
                if no ghosting, problem is fuser.
                Stick with OEM pcu's and toner. And when rebuilding the fuser, do everything...Heat roller, pressure roller, press bushings, thermistor, pick feet
                Do it right and these machines are bullet proof
                • jacky lin
                  • Dec 2022
                  • 7
                  oem toner higher probability
                  • Gift
                    • Mar 2011
                    • 2458
                    My first thought was also the pressure roller bushings or the pressure roller itself.
                    25mm circumference is too little for both drum and fuser rollers though - it could match to the transfer roller.
                    • tsbservice
                      Field tech
                      • 7976
                      Thanks for the input guys, we aren't Ricoh dealers so getting parts and pricing can be tricky. Waiting for clients decision what will they want to do with this machine.
                      • Gift
                        • Mar 2011
                        • 2458
                        Usually I'd say "toss it" or check the SP values for the voltages. Like I said a pattern with 25mm can't match to both fuser and drum. I think the charge roller is involved in the drum cleaning process since it has contact all the time. Another thing that pops in my mind: Did you check the erase lamps/LEDs? If they won't work it's pretty likely that the charge roller pick up dirt and give it back to the drum and/or rear side of the prints.
                        If you install a new PCU you also shouldn't trust that it will initialize properly by itself and don't forget that you still have a certain amount of compatible toner left in the hopper (if you didn't vacced it out). Some techs also perform some skyshots (without toner suply) before initializing the PCU - a slightly lighter density might help eliminating or reducing other issues.
                        • luca72
                          • Oct 2017
                          • 1745
                          you said that the fuser has never been disassembled, so it could simply be the thermistors that need to be cleaned, or they are detuned/failed and do not read the temperature values well and need to be replaced (I had the same problem just last week on a mp4054 )
                          "I'll be back"
                          • Gab
                            • Aug 2015
                            • 668
                            sometimes is the blade . MAke a copy and stop it just after oaoer passes drum and see it is ghost
                              • 37360
                              I see I am not the only one who hits the O when going for the P
