aficio 450 white copy
  • Jun Tadeja
    I have a white copy of my aficio 450, can any body help me.
    And a problem that the copy does not get out of the machine, but there's no error code popping at the panel.
  • mikadonovan
    • May 2008
    • 2931
    Make sure your original is face up when you run it through the document feeder.
    NEVER ASSUME ANYTHING
    • fitsy.13
      senior tech
      • 64
      print of the meter reading if you have an image then your not putting the orginals the right way
      • stephaneleclere
        • Sep 2008
        • 15
        It seems to be a problem with the laser motor.
        Good luck.
        • smiley
          • Aug 2008
          • 615
          Good luck.
          right' just print out the counter 1st.
          there is no glory without sacrifice
          • schooltech
            School District Tech
            • Jun 2008
            • 504
            I also think you have a mirror motor dying on you-or it's probably dead by now.
            Do an internal meter print.
            Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
            • Frank12
              • Nov 2008
              • 77
              try to replace charge power pack, golden cup ka dati
              • salmandol
                • Mar 2009
                • 107
                Had this problem last week. DV unit seized causing paddle roller to break causing blank copies.
                but first Make sure originals are set correctly.
                Check DV unit gears.
                • Jun Tadeja
                  i did replace the charge power pack and solve the problem, cno ka bat cnabi mo dati golden cup ka
                  • Frank12
                    • Nov 2008
                    • 77
                    c frank butch ko sila ariel limmuel dindo third kmi ung training nyo dati
