Ricoh MPC 3001 SC 120 121 101
  • lazamarius2
    • Apr 2020
    • 2
    Hello there , I have a big problem and I just can`t imagine what else to do.I have these SC errors 120 121 101 , the machine work normal on print only when using platen glass and ADF will pop these errors.
    I changed the following :
    -entire scaning unit chasis from a machine that works
    -all the electronics board inside including SBU , BICU, HP sensor,Laser unit, everything you can think.
    And still the error will not go away.
    If you have any ideas please .
  • dalewb74
    • Feb 2018
    • 1153
    Re: Ricoh MPC 3001 SC 120 121 101
    firmware?
      • 37487
      I would suspect the cable between the SIO board on the back of the scanner unit and the BICU or the BICU.
      • lazamarius2
        • Apr 2020
        • 2
        Hello, thx for replies!
        I have found other technicians who worked at magenta pump and the wire from the pump was wrecked and causing a shorcircuit or a mass. Now it's fully working.
